Guidance on QoS set-up for voice between IPSEC VPN connected sites
mitchen
Level 2
Level 2
I have 3 sites.  Each site has a Cisco 1841 as its WAN router with a 10Mb direct internet access circuit connected to Fa0/0.  The sites are then connected to each other via site-to-site IPSEC VPN.  (The LAN switches in use at each site are Cisco 3750 series)
Site A    10.10.1.0/24 – data (VLAN50)
                10.50.1.0/24 – voice (VLAN55)
Site B     10.10.2.0/24 – data (VLAN50)
                10.50.2.0/24 – voice (VLAN55)
Site C     10.10.3.0/24 – data (VLAN50)
                10.50.3.0/24 – voice (VLAN55)
Now, Site A has already been set-up with VoIP telephony.   The plan is to extend this to the other 2 offices.
Auto QoS has been set-up on the switches and data and voice VLANs created in the same way for each office.
The question is, how should/do we extend the QoS for the voice over the WAN to ensure voice quality remains for site to site calls.  And what special considerations do we have to make for it being IPSEC VPN connectivity between the sites?  The actual IP telephony system itself is being set-up by a 3rd party and not a lot of information on their requirements has been forthcoming so far – essentially all we have really been told is that they would like us to “reserve” a certain amount of bandwidth for the voice traffic between each site.
Can anyone offer any advice/guidance on this?
Thanks.
sakella
Here is an example for site A
access-list 100 permit udp 10.50.1.0 0.0.0.255 any
access-list 101 permit ip 10.50.1.0  0.0.0.255
class-map match-any VOICE
match access-group 100
class-map match-any DATA
match access-group 101
policy-map QOS
class voice
priority per 50<-(change the bandwidth as per your requirments)
class data
bandwidth 10
int fa0/0 (configure on the outgoing WAN interface on site A)
service-policy out QOS
Here is the  document for preclassify
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a008017405e.shtml
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a00800b3d15.shtml#t4
Thanks, that information looks very helpful.
Yes.. Setup QoS as you would for a normal WAN based on the circuit speed, total number of calls, Codec etc..
The use the QoS-preclassify command on the interfaces for the VPN tunnel.
You'll also need to remember that if your sending voice over the internet, then you'll be at the mercy of the internet and it's issues.
