HA setup for CSR 1000v in AWS
Abhi11
Hi Team,
We have deployed cisco vCSR solution in AWS. Now we are trying to implement  HA solution for cisco vCSR 1000v in  AWS . Done the setup in Test environment  But getting issues during the HA fail over.
Getting below error in logs. Any help would be great. We need to implement this in our prod setup once this successful.
*Aug 5 09:50:52.579: CLOUD-HA : AWS - httpc request sent
*Aug 5 09:50:52.579: CLOUD-HA : AWS httpc_send_request return (0x1)
*Aug 5 09:50:52.579: CLOUD-HA : vxe_cloud_ha_aws_parse_resp: exit
*Aug 5 09:50:52.113: %SELINUX-3-MISMATCH: R0/0: audispd: type=AVC msg=audit(1628157052.111:128): avc: denied { execute } for pid=2068 comm="linux_iosd-imag" name="bash" dev="rootfs" ino=1605 scontext=system_u:system_r:polaris_iosd_t:s0 tcontext=system_u:object_r:shell_exec_t:s0 tclass=file permissive=1
*Aug 5 09:50:52.114: %SELINUX-3-MISMATCH: R0/0: audispd: type=AVC msg=audit(1628157052.111:128): avc: denied { execute_no_trans } for pid=2068 comm="linux_iosd-imag" path="/bin/bash" dev="rootfs" ino=1605 scontext=system_u:system_r:polaris_iosd_t:s0 tcontext=system_u:object_r:shell_exec_t:s0 tclass=file permissive=1
*Aug 5 09:50:52.122: %SELINUX-3-MISMATCH: R0/0: audispd: type=AVC msg=audit(1628157052.111:128): avc: denied { map } for pid=2068 comm="sh" path="/bin/bash" dev="rootfs" ino=1605 scontext=system_u:system_r:polaris_iosd_t:s0 tcontext=system_u:object_r:shell_exec_t:s0 tclass=file permissive=1
*Aug 5 09:50:52.132: %SELINUX-3-MISMATCH: R0/0: audispd: type=AVC msg=audit(1628157052.131:129): avc: denied { execute } for pid=2069 comm="sh" name="date" dev="rootfs" ino=1601 scontext=system_u:system_r:polaris_iosd_t:s0 tcontext=system_u:object_r:bin_t:s0 tclass=file permissive=1
*Aug 5 09:50:52.132: %SELINUX-3-MISMATCH: R0/0: audispd: type=AVC msg=audit(1628157052.132:130): avc: denied { execute_no_trans } for pid=2069 comm="sh" path="/bin/date" dev="rootfs" ino=1601 scontext=system_u:system_r:polaris_iosd_t:s0 tcontext=system_u:object_r:bin_t:s0 tclass=file permissive=1
*Aug 5 09:50:52.133: %SELINUX-3-MISMATCH: R0/0: audispd: type=AVC msg=audit(1628157052.132:130): avc: denied { map } for pid=2069 comm="date" path="/bin/date" dev="rootfs" ino=1601 scontext=system_u:system_r:polaris_iosd_t:s0 tcontext=system_u:object_r:bin_t:s0 tclass=file permissive=1
*Aug 5 09:50:52.593: CLOUD-HA : AWS resp data alloc length=4294967295
*Aug 5 09:50:52.594: CLOUD-HA : aws_reg_httpc_resp_data app_context=0x7FE45CC903C8
*Aug 5 09:50:52.594: CLOUD-HA : AWS - process HTTP resp. ctx=0x7FE45CC903C8
*Aug 5 09:50:52.594: CLOUD-HA : res content len=262
*Aug 5 09:50:52.594: CLOUD-HA : res content iov_len=261 iov_base=<?xml version="1.0" encoding="UTF-8"?>
<Response><Errors><Error><Code>InvalidHttpRequest</Code><Message>The HTTP request is invalid. Reason: Unable to parse request</Message></Error></Errors><RequestID>0c9b441e-b04b-475f-a65e-96f807757d5e</RequestID></Response>
*Aug 5 09:50:52.594: CLOUD-HA : vxe_cloud_ha_aws_parse_resp: state=FINI data=<?xml version="1.0" encoding="UTF-8"?>
*Aug 5 09:50:52.594: CLOUD-HA : AWS vxe_cloud_ha_aws_next: current state=FINI
*Aug 5 09:50:52.595: CLOUD-HA : AWS system cmd = sh /usr/binos/conf/aws_ha_rr.sh FINI
*Aug 5 09:50:52.620: CLOUD-HA : AWS - process_result: parse awsha.out file
*Aug 5 09:50:52.620: CLOUD-HA : AWS CMD=EBADRQC
*Aug 5 09:50:52.620: %VXE_CLOUD_HA-3-FAILED: VXE Cloud HA BFD state transitioned, HA node 1 event route update failed
*Aug 5 09:50:52.620: CLOUD-HA : vxe_cloud_ha_aws_parse_resp: exit
5 Replies 5
Mark Elsen
 - Review this document : https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-access-registrar/213601-csr1000v-ha-redundancy-deployment-guide.html
  Also checkouthttps://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-access-registrar/213601-csr1000v-ha-redundancy-deployment-guide.html#anc26    not exactly what you see , but follow it's guidelines (too)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Abhi11
Thanks for the reply. We have followed this document. But getting the error as updated in the initial post.
We are getting VXE_CLOUD_HA-3-FAILED: VXE Cloud HA BFD state transitioned, HA node 1 event route update failed
Let me know any solution for this.
Abhi
 - No specific insights , but I would also look into the software version being used and make sure it is recent and preferably an advisory release.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
version 17.3.3
How to find the serial no for this cisco cloud service router 1000v ?
show version and show license udi  these 2 commands tried but not the getting the serial no.
              >...how to find serial number
           - Try : show  license udi
M.
       Beauty and terror
      Just keep going
       No feeling is final
