Hardware command to verify nexus 5020
Hi all,
Anyone can tell me the correct command to check the hardware of a Nexus 5020, like the show Inventori, show diag etc?
Used the same or is there a specific one for these items?
some example?
Kind Regards!
Bilal Nawaz
Hello, you can use any of these to give you more information about the device:
Show inventory
Show module
Show hardware internal
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Excellent !
Thank you very much Bilian
Kind Regards!!!
