Have anyone used HWIC-4T ?
msara
I would like to enquire on above mentioned product. As I believe it is mentioned this high speed wan interface card has 4 serial ports which can support maximum 8Mbits/sec EACH port. That would mean total of 32MBits/sec.
1) Can I confirm if I can make use of each port with 8Mbits each to total 32Mbit/sec and this supported by 2821 backplane?
2) What is the bandwidth option I have? Example say if I would like to have 10Mbit wan link, can I install 8Mbit on serial0 and 2Mbit on serial1 ? Is there bandwidth increment patterns on each serial?
3) This serial ports I believe uses the same types of cable like for WIC-2T. Can I confirm on that? Would I be able to use V.35 solution and subscribe Lease Line BW accordingly from telco?
Any other limitation ?
spremkumar
Level 9
Level 9
1) As per the datasheet it does supports 8Mbps per port do refer this link for the same.
http://www.cisco.com/en/US/products/ps5949/products_qanda_item0900aecd80274424.shtml
3) Also the ports are smartserial similar to WIC-2T.
HWIC-4T, HWIC-4A/S Smart Serial ..
http://www.cisco.com/en/US/products/ps5949/products_data_sheet0900aecd80274416.html
regds
