Having bgp routes but unable to ping
vamsi007
R1====
interface Loopback0
ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet0/0
ip address 192.1.100.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 192.1.25.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router bgp 100
bgp log-neighbor-changes
network 10.1.1.0 mask 255.255.255.0
network 192.1.25.0
neighbor 192.1.100.3 remote-as 100
sh ip route
6.0.0.0/24 is subnetted, 1 subnets
B 6.6.6.0 [200/1] via 192.1.100.3, 02:31:49
10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
C 10.1.1.0/24 is directly connected, Loopback0
L 10.1.1.1/32 is directly connected, Loopback0
B 10.2.2.0/24 [200/0] via 192.1.100.3, 02:31:49
B 10.5.5.0/24 [200/1] via 192.1.100.3, 02:31:49
B 10.7.7.0/24 [200/1] via 192.1.100.3, 02:31:49
B 10.11.11.0/24 [200/0] via 192.1.100.3, 02:31:49
192.1.25.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.1.25.0/24 is directly connected, GigabitEthernet0/1
L 192.1.25.1/32 is directly connected, GigabitEthernet0/1
B 192.1.50.0/24 [200/0] via 192.1.100.3, 02:31:49
B 192.1.70.0/24 [200/0] via 192.1.100.3, 02:31:49
192.1.100.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.1.100.0/24 is directly connected, GigabitEthernet0/0
L 192.1.100.1/32 is directly connected, GigabitEthernet0/0
ON ROUTER R3
ip address 192.1.100.3 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 192.1.20.3 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
ip address 192.1.24.3 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 192.1.30.3 255.255.255.0
duplex auto
speed auto
media-type rj45
router bgp 100
neighbor 192.1.20.2 remote-as 200
neighbor 192.1.30.10 remote-as 64512
neighbor 192.1.100.1 remote-as 100
neighbor 192.1.100.1 next-hop-self
sh ip route
Gateway of last resort is not set
B 6.6.6.0 [20/1] via 192.1.30.10, 04:17:26
10.0.0.0/24 is subnetted, 5 subnets
B 10.1.1.0 [200/0] via 192.1.100.1, 02:47:43
B 10.2.2.0 [20/0] via 192.1.20.2, 04:07:42
B 10.5.5.0 [20/1] via 192.1.30.10, 04:17:26
B 10.7.7.0 [20/1] via 192.1.30.10, 03:36:47
B 10.11.11.0 [20/0] via 192.1.30.10, 04:17:26
192.1.20.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.1.20.0/24 is directly connected, GigabitEthernet0/1
L 192.1.20.3/32 is directly connected, GigabitEthernet0/1
192.1.24.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.1.24.0/24 is directly connected, GigabitEthernet0/2
L 192.1.24.3/32 is directly connected, GigabitEthernet0/2
B 192.1.25.0/24 [200/0] via 192.1.100.1, 02:52:59
192.1.30.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.1.30.0/24 is directly connected, GigabitEthernet0/3
L 192.1.30.3/32 is directly connected, GigabitEthernet0/3
B 192.1.50.0/24 [20/0] via 192.1.30.10, 04:17:26
B 192.1.70.0/24 [20/0] via 192.1.30.10, 04:17:26
L 192.1.100.3/32 is directly connected, GigabitEthernet0/0
ON ASA
nameif outside
security-level 0
ip address 192.1.30.10 255.255.255.0
description DMZ-5
nameif DMZ-5
security-level 50
ip address 192.1.50.10 255.255.255.0
nameif inside
security-level 100
ip address 10.11.11.10 255.255.255.0
description DMZ-7
nameif DMZ-7
security-level 50
ip address 192.1.70.10 255.255.255.0
D 6.6.6.0 255.255.255.0 [90/130816] via 10.11.11.6, 03:37:36, inside
B 10.1.1.0 255.255.255.0 [20/0] via 192.1.30.3, 02:51:07
B 10.2.2.0 255.255.255.0 [20/0] via 192.1.30.3, 03:37:36
D 10.5.5.0 255.255.255.0 [90/130816] via 192.1.50.5, 03:37:36, DMZ-5
D 10.7.7.0 255.255.255.0 [90/130816] via 192.1.70.7, 03:37:36, DMZ-7
C 10.11.11.0 255.255.255.0 is directly connected, inside
L 10.11.11.10 255.255.255.255 is directly connected, inside
B 192.1.25.0 255.255.255.0 [20/0] via 192.1.30.3, 02:55:58
C 192.1.30.0 255.255.255.0 is directly connected, outside
L 192.1.30.10 255.255.255.255 is directly connected, outside
C 192.1.50.0 255.255.255.0 is directly connected, DMZ-5
L 192.1.50.10 255.255.255.255 is directly connected, DMZ-5
C 192.1.70.0 255.255.255.0 is directly connected, DMZ-7
L 192.1.70.10 255.255.255.255 is directly connected, DMZ-7
ON ROUTER R6
sh ip route
6.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 6.6.6.0/24 is directly connected, Loopback0
L 6.6.6.6/32 is directly connected, Loopback0
D EX 10.1.1.0/24
[170/281856] via 10.11.11.10, 02:56:21, GigabitEthernet0/0
D EX 10.2.2.0/24
[170/281856] via 10.11.11.10, 02:58:20, GigabitEthernet0/0
D 10.5.5.0/24 [90/131072] via 10.11.11.10, 04:28:07, GigabitEthernet0/0
D 10.7.7.0/24 [90/131072] via 10.11.11.10, 03:46:03, GigabitEthernet0/0
C 10.11.11.0/24 is directly connected, GigabitEthernet0/0
L 10.11.11.6/32 is directly connected, GigabitEthernet0/0
D EX 192.1.25.0/24 [170/281856] via 10.11.11.10, 02:58:20, GigabitEthernet0/0
D 192.1.50.0/24 [90/3072] via 10.11.11.10, 04:39:39, GigabitEthernet0/0
D 192.1.70.0/24 [90/3072] via 10.11.11.10, 04:32:23, GigabitEthernet0/0
Hello
By default icmp is prohibited to be initiated externally traveling towards or through the asa fw this is because the wan interface usually always has a lower security level than any other interface on the fw and traffic from a lower level interface towards a higher level interface is by default denied that is unless it is allowed with an access-list, Icmp traffic that is initiated from a higher level interface to a lower level is allowed but the returning echo reply needs to be enabled for inspection and this inspection isn't enabled by default.
So to allow returning icmp echo-reply through the ASA fw you can can apply the following:
policy-map global_policy
class inspection_default
inspect icmp
To allow icmp to be initiated externally from the fw then you need an access-list
access-list 100 extended permit icmp any any
access-group 100 in interface outside
Kind Regards
Paul
Hello
inspect icmp
Kind Regards
Paul
Thanks paul your solution worked,and one more doubt regarding this topology,i am getting ping only when i used source loopback from bgp router,what changes should i make to bgp router to get ping with physical interface as source
Router# ping 6.6.6.6 source 10.1.1.1
Sending 5, 100-byte ICMP Echos to 6.6.6.6, timeout is 2 seconds:
Packet sent with a source address of 10.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 6/12/20 ms
Success rate is 0 percent (0/5)
Hello
it sounds like you need to also advertise the physical interface addressing so reachability is established sourcing from those interfaces.
note: if they are originally advertised via eigrp this routing process by default is classfull so you may need to turn off autosummarisation so they get advertised correctly
router eigrp x
mo auto summary
Kind Regards
Paul
