having trouble setting up a 2801 as an internet router
rschmalzbauer
I'm having trouble setting up a Cisco 2801 as an internet router between our firewall & our ISP.
I've setup FastEthernet0/0 as the WAN port & FastEthernet0/1 as the LAN port.  I've setup a default gateway pointing the next hop (the ISP)
when I plug in a pair of laptops configured to mimic our IP scheme, I'm able to ping thru, but when I put the router between our firewall & ISP I'm not able to get out to the internet (can't ping google)  I can still ping the next hop.
Our old router died, so I am unable to pull up its configuration.
Can someone point me in the right direction?  Here is the code I'm come up with so far.
names & IPs have been changed to protect the innocent.
Thanks!
Current configuration : 858 bytes
version 15.0
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$R6qT$KczCsj9FnEM.qraks2BeN.
enable password xxxxxxxx
no aaa new-model
ip source-route
ip cef
license udi pid CISCO2801 sn FTXxxxxxxx
interface FastEthernet0/0
ip address 65.36.76.34 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 65.36.78.29 255.255.255.224
speed auto
full-duplex
no mop enabled
ip default-gateway 65.36.76.33
ip forward-protocol nd
no ip http server
access-list 98 deny   any
control-plane
line con 0
line aux 0
line vty 0 4
access-class 98 in
password xxxxxxxx
login
scheduler allocate 20000 1000
end
Joseph W. Doherty
Disclaimer
The Author of this  posting offers the information contained within this posting without  consideration and with the reader's understanding that there's no  implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind.  Usage of  this posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You might want to try replacing your:
with
ip route 0.0.0.0 0.0.0.0 65.36.76.33
Beyond that much depends on what the downstream and upstream devices expect as where certain subnets are.
6 Replies 6
cadet alain
It would help having  a diagram and the firewall config as well as exactly what is not working and what is working.
Regards.
Alain.
thank for quick response.
FYI, everything works now, as I'm using a SonicWall firewall (with firewall turned off) to route this traffic, but when I try using the Cisco 2801, I can't get past the default gateway.
Any traceroutes I attempt stop at the router (65.36.78.29)
Joseph W. Doherty
Disclaimer
Posting
with
Thanks Joseph,
I'll try replacing that default gateway with a route.
Hopefully it's something simple like that.
That was it.  Thanks Joseph.
Disclaimer
Posting
Great!
