HDLC subinterface and EIGRP
oguarisco
Level 3
Level 3
is it possible to configure two WAN subinterface using HDLC as encapsulation and running EIGRP over the subinterface?
Using Frame-Relay mode Back-to-Back all is working fine but with HDLC nothing is working
Omar
5 Replies 5
stephtchoko
Level 3
Level 3
Good day,
you can't configure subinterface with hdlc. you need frame-relay for it.
Normally, if you use hdlc with back to back without subinterface, it'll work.
When you configure hdlc, you ping the remote interface serial ?
Regards.
As I supposed...With HDLC you can ping both the remote and local IP interfaces...thuis is not happening using Frame-relay depending on which type of sub-interface are you configuring
Saluti
Omar
please, send us configuration for eigrp with hdlc.
Regards.
nothing particular using standard serial interface
EIGRP works normally without need to configure some special command
see http://www.cisco.com/en/US/partner/tech/tk713/tk237/technologies_q_and_a_item09186a008009457a.shtml
Why am I unable to ping my own interface address?
i believe i don't understand , your issue. Can you be clear ??
Regards.
