HDSL backup via ADSL
proxel
Hi all,
I have two links to Internet: the primary via HDSL to ISP1 and the secondary via ADSL to ISP2.
Is there a way to use the ADSL link as an automatic backup of the HDSL link?
TIA
Stefano
Hum, very interesting!!!
The last problem I have is that I must also translate the internal private IP addresses in different public addresses using the HDSL/ADSL interfaces.
Any other suggestion?
Thanks for the moment
Stefano
You can use pix or other firewall to nat before you hit the router. Thst would be your best bet. In addition if you use the ADSL's ISP modem it will probably do nat anyways. All the best.
