HELP! BGP Multihoming configuration template
chuckholley
I have a project I have been given...I have two separate routers which will each be peering with a different ISP.  I have a registered ASN and IP address block that I will be advertising.  I would like to load share between the two ISP's. I think I need to run iBGP between the two routers, which will be in the same closet.
  I am just looking for a proven template to help me get this off the ground, I am under the gun for the configuration, just need a little assist.  Thank you in advance!!
have a look at the link below and scroll down to Topology 6:
http://showipbgp.com/bgp-configurations/cisco.html
