03-03-2019 06:24 AM
I’m in the process of setting up my new Cisco 891 Router for connection to the internet via BT Infinity Broadband. I’m also very new to the Cisco configuration command set and have pieced together what I feel is a workable solution from examples I’ve been reading from the forum and various articles on-line.
Before entering my configuration, I would be very grateful if one of you experts out there cold tell me if what I’ve put together is correct given what I’m trying to achieve.
My requirement are as follows:
I would like to allow computers on my internal 192.168.1 network to connect to the internet in the usual way.
I would like the Cisco router to handle my 192.168.1 DHCP Pool.
I have 3 static IP addresses provided by my ISP of which two of them will be mapped to 192.168.1 addresses on my internal network. These two addresses will by used to remotely access security cameras on port 8000. In my mock up config these are the 217.40.174.221 and 217.40.174.222 addresses.
I would like to use my third public address 217.40.174.223 80 in my example to permit outside traffic though to my internal mail server.
That’s about it and thank you in advance for any help you can provide.
Here's my mock up configuration
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool vlan1pool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 213.120.234.70
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
description ### WAN interface ###
no ip address
ip nat outside
pppoe enable group global
pppoe-client dial-pool-number 1
no shutdown
interface Vlan 1
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface dialer 1
ip address negotiated
ip mtu 1492
encapsulation ppp
ppp authentication chap
dialer pool 1
dialer-group 1
ppp chap hostname click@bt.com
ppp chap password 0 btclick@bt.com
ppp sent-usrername btclick@bt.com password 0 btclick@bt.com
ip nat inside source list 1 interface dialer 1 overload
ip nat inside source static udp 192.168.1.41 8000 217.40.174.221 8000 extendable
ip nat inside source static udp 192.168.1.42 8000 217.40.174.222 8000 extendable
ip nat inside source static tcp 192.168.1.43 80 217.40.174.223 80 extendable
ip route 0.0.0.0 0.0.0.0 Dialer 1
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit tcp any any established
03-03-2019 06:54 AM
All other configurations are correctly. Just nat configuration need adjust. Set command below under dialer interface.
ip nat outside
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip nat outside
no shutdown
interface Vlan 1
ip nat inside
interface dialer 1
ip nat outside
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
03-03-2019 07:40 AM
on a side note, if you got three static IP addresses (for which you have probably paid) you might as well configure one of them on the dialer interface:
interface dialer 1
ip address 217.40.174.221 x.x.x.x
03-04-2019 07:17 AM
