Help for router rommon mode
My cisco 2620 router always boots into rommon mode but after i reset it, it boots into the IOS. After i shutdown the router and power it up again it goes back to rommon mode ?
I saved the running config to the startup config after setting up the registry to 0x2102 but it didn't help
I urgently need help so if anyone can help me to sove this problem it will be a great help
Thank you
When your router boot, you must check files presents on flash with command "show flash".
If there are more than one .bin file, you must specify the file that will used during boot process:
router(conf)# boot system flash:c2600-ipvoice-mz.123-11.T11.bin
Leo Laohoo
If you have 0x2102 and it keeps booting into ROMmon, there can be a few "usual suspect".
1.  Your boot statement don't match the current filename available; or
2.  There could be errors during the bootup process.  It would be nice if you post the output of the bootup process.
