help if needed on my attached configurations
amralrazzaz
Level 5
Level 5
Dear all
i need support and opinion for my attached 3 files for my isr router 2911 and 2 switches  ws-c2960x-24ps-l
i need to know if its fine ? or need to add some command lines or any modification please share to apply it on my devices
many thanks in advance for your great support
amr alrazzaz
configs look fine at first glance. Is there a specific problem you are running into ?
no sir im just asking for any new command that i miss or security issue ? any services that i need to enable or disable ?
its just like if i miss any configurations or something ? :)
also i dont have firewall in my network so if there are any to secure my connection or network !! i dont know :)
amr alrazzaz
any missing  useful configurations that i should use ?
amr alrazzaz
configuration wifi client and guest using cisco aironet 2500 series  AP on switch ?
how to configure the switch port ? connected to AP and what kind of port ? and how to configure 2 vlans ? one for guest and one for client ?
amr alrazzaz
