Help me to select switch type?
pabelkid86
I want to select switch that support two function : Ethernetchannel and GigabitEthernet. Please help me to list some this switch that have this function. And, could you tell me price of this switch type.
2 Accepted Solutions
vmiller
Level 7
Level 7
Leo Laohoo
Gee whiz.  This is a tall order.  Do you have any other information?  8, 12, 24 or 48 port?  PoE or non-PoE?  Chassis-based or not?
Layer 2 switches (Gig)
2350/2360, 2975, 2960G, 2960S
Layer 2/Layer3 switches (Gig)
3560G, 3750G, 3560E/3560X, 3750E/3750X
5 Replies 5
vmiller
Level 7
Level 7
have you looked at the cisco products page ?
http://www.cisco.com/en/US/products/hw/switches/index.html
Leo Laohoo
Thanks for your support.
Yes, i want to find the sw layer 2 (support or non-support PoE is Ok).
As, enclosed file i show you the aggregate link: 300 + 300=600 (Mbps).
And, i only need sw from 8 to 12 port.
Could you show me the sw type exactly?
Right.  This narrows down a fair bit.
WS-C2960G-8TC-L is 7 10/100/1000BaseTx port.
There are no other 8 or 12 ports that are Gig.  There are 8 or 12 ports that are only 10/100BaseTx.
Yes, I have one more question
I read on internet, Etherchannel function of SW is defined by 802.3ad standard (Wikipedia.com). And all cisco SW have the ability to support EtherChannel.
So, when i chose sw, can i base on 802.3ad standard or others?
BR/
