Help me with my 3660 router showing garbage
darksilver26
help me please.... what's wrong with my 3660 router?
it shows garbage upon boot up
"óXTNxØ.óX.óxNX.X.X.X.NxT.xÐNxNXØNxN.xÛNx.X.X.X.X.XT.XTNxÐN.xNXÚ.XNXNxNxX.XNxTNX.X.xL.xÚNNxT.xT.xØNxNXÐNxNxO.xÛNNxL.x.X.XxNX.XT.XÐ.X.xLXÚNNxT.x.XNXNNx.XNxÐNxNxL.xØNNxT.XNxO.xØNX.xNXÚNNx.XÐ.XNXNxNx\.xØN8NxTNx.XNxN.xÛNX.XNxNxNXØNxNXÐ.X.NxN.xÛNNXNX.X.X.xÐNxNxNxÐNxN.xÚNNx\.X.6.zXØxNNx.XNxNX.NxT.xØNxNxO.X.zO"
Console port(router)<=>RJ45<=Rollover=>RJ45<=>Modular RS232 adapter(Female)<=>RS232 Port(male com1)
help me please...
7 Replies 7
Peter Paluch
Hello Carl,
It is possible that the console port speed has been changed from the default setting of 9600bps to a different value. That is the most common reason for seeing the garbage. In your terminal software (HyperTerminal, PuTTY, etc.), try changing the COM port speed, starting from 1200bps and proceeding through 2400, 4800, 9600, 19200, 38400, 57600 to 115200 bps. Each time you change a setting, hit Enter a couple of times to see if the router starts responding normally. If not, proceed to the next available setting.
Should you find the appropriate setting, you may either keep it, or put the console speed back to 9600bps using the commands:
configure terminal
line con 0
speed 9600 ! After entering this, the console will stop again - change back to 9600 bps
end
Best regards,
Peter
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n  [n]:  y
Ready to receive file c3660-i-mz.120-7.t.bin ...
Erasing flash at 0x307c0000
program flash location 0x30410000
Download Complete!
*** GT64120 Master Abort Interrupt ***
PC = 0x80005624, Cause = 0x4000, Status Reg = 0x3041f003
monitor: command "xmodem" aborted due to exception
i got this error whenever i tried to upload an IOS.
Can you try with tftpdnld in ROMMON:  http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Regards.
Alain.
thank you for your response.
but unfortunately
tftpdnld is not supported in my 3660 router.
rommon 1 > ?
alias               set and display aliases command
boot                boot up an external process
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
context             display the context of a loaded image
cookie              display contents of motherboard cookie PROM in hex
dev                 list the device table
dir                 list files in file system
dis                 disassemble instruction stream
dnld                serial download a program module
frame               print out a selected stack frame
help                monitor builtin command help
history             monitor command history
iomemdef            set IO mem to a default 25%
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
set                 display the monitor variables
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
unalias             unset an alias
unset               unset a monitor variable
xmodem              x/ymodem image download
TFTPDNLD is not supported on the 3660, but, look at the following link:
http://www.cisco.com/en/US/partner/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
XMODEM is the only option, although if you have a PCMCIA card, you can upload the IOS there and try to recover it.
I can recommend you to try xmodem again with 2 options:
1- Regular xmodem of the image to the flash
2- Xmodem to the DRAM directly
For option 1, use the following configuration:
  1. rommon 2 > confreg
    do you wish to change the configuration? y/n [n]:  y
    enable  "diagnostic mode"? y/n  [n]: n
    enable  "use net in IP bcast address"? y/n  [n]: n
    disable "load rom after netboot fails"? y/n  [n]: n
    enable  "use all zero broadcast"? y/n  [n]: n
    enable  "break/abort has effect"? y/n  [n]: n
    enable  "ignore system config info"? y/n  [n]: n
    change console baud rate? y/n  [n]:  y
    enter rate: 0 = 9600,  1 = 4800,  2 = 1200,  3 = 2400
                4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200  [7]:  7
    change the boot characteristics? y/n  [n]:  y
    enter to boot:
    0 = ROM Monitor
    1 = the boot helper image
    2-15 = boot system
        [0]:  0
        Configuration Summary
    enabled are:
    console baud: 115200
    boot: the ROM Monitor
    do you wish to change the configuration? y/n  [n]: n
    You must reset or power cycle for new config to take effect
    rommom 2 > reset
  2. Open a new hyperterminal with these settings:
    Bits per second - 115200
    Data bits - 8
    Parity - None
    Stop bits - 1
    Flow control - Hardware
  3. After setting the hyperterminal, you receive a rommon prompt. Enter             the xmodem command. Before you enter an             xmodem command, there should be a software image             residing in your terminal or your local hard drive.
    rommon 2 > xmodem -c c3660IOS.bin
For option 2 just change the last option:
rommon 2 > xmodem -r c3660IOS.bin
I recommend you to use a small image to make the upload faster and then upgrade to the image you want to use using regular TFTP.
If the problem persist on the second option we could be looking at a hardware problem.
Cheers,
Yanil
thank you for the reply....
i tried your suggestions still wasn't able to boot the router aside from rommon mode..
but odd..
i got 1 flash which i havent reflash with a newer IOS.
i put it back on and i was able to veryify with no checksum error...
i manage to boot fully upto the configuration mode
i was also able to show run and show version.
but while idle.. it show a message "bad ram on location "hex value" "
it hangs-up..
i shutdown the router...
then boot it up...
back to rommon mode and had a checksum error
Hi Carl,
It does sound like a hardware problem. To verify we can try with a different IOS image if it doesn't boot, then we can assume it is hardware.
Cheers,
Yanil
