Help needed: ADSL connection problem with VRFs
omeravrech
Community Member
I have a problem with my internet connection. I have a few internet connections of ADSL and each one is in a different VRF, when I try to connect with all of them at the same time it doesn't work, when I connect them separately, just one it works
My configuration:
ip vrf lan
rd 100:1
route-target import 100:1
route-target import 200:1
route-target import 300:1
route-target import 400:1
route-target import 500:1
ip vrf vrf1
rd 200:1
route-target export 200:1
route-target export 100:1
ip vrf vrf2
rd 300:1
route-target export 300:1
ip vrf vrf3
rd 400:1
route-target export 400:1
ip vrf vrf4
rd 500:1
route-target export 500:1
interface ATM0/0/0
description FORWARDING_DIALER_01
ip vrf forwarding vrf1
no ip address
ip flow ingress
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/48
pppoe-client dial-pool-number 1
interface ATM0/1/0
description FORWARDING_DIALER_02
ip vrf forwarding vrf2
no ip address
ip flow ingress
pvc 8/48
pppoe-client dial-pool-number 2
interface ATM0/2/0
description FORWARDING_DIALER_03
ip vrf forwarding vrf3
no ip address
ip flow ingress
pvc 8/48
pppoe-client dial-pool-number 3
interface ATM0/3/0
description FORWARDING_DIALER_04
ip vrf forwarding vrf4
no ip address
ip flow ingress
pvc 8/48
pppoe-client dial-pool-number 4
interface Dialer1
no ip address
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username ########## password 0 ##########
interface Dialer2
no ip address
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
interface Dialer3
no ip address
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 3
dialer-group 3
interface Dialer4
no ip address
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 4
dialer-group 4
ip classless
ip route vrf lan 0.0.0.0 0.0.0.0 Dialer1
ip route vrf lan 0.0.0.0 0.0.0.0 Dialer2
ip route vrf lan 0.0.0.0 0.0.0.0 Dialer3
ip route vrf lan 0.0.0.0 0.0.0.0 Dialer4
ip route vrf lan 192.168.0.0 255.255.0.0 192.168.201.1
ip http server
no ip http secure-server
ip nat inside source route-map adsl1 interface Dialer1 vrf lan overload
ip nat inside source route-map adsl2 interface Dialer2 vrf lan overload
ip nat inside source route-map adsl3 interface Dialer3 vrf lan overload
ip nat inside source route-map adsl4 interface Dialer4 vrf lan overload
access-list 1 permit any
access-list 2 permit any
access-list 3 permit any
access-list 4 permit any
route-map adsl2 permit 10
match interface Dialer2
route-map adsl3 permit 10
match interface Dialer3
route-map adsl1 permit 10
match interface Dialer1
route-map adsl4 permit 10
match interface Dialer4
11 Replies 11
paolo bevilacqua
What do you have vrf for? If the goal is just to use all circuits at same time, that is not necessary.
Beside that, the nat router map should also map an ACL, not just interface.
So what do you recommend to config it?
By the way, I have 9 links, not 4 like i wrote. because of the capacity check I can't write them all
I have 9 users to my ISP and because of this I have done the 9 VRFs. I need that all of my 9 users work together in a load-balancing mode.
You don't need VRF for that.
how?
i try without, it's still not work...
You have then a configuration problem, because it is known to work.
this is the reason that I ask you. can you give me a configuration's example? cuz' I don't know what to do anymore...
Post your own once has been cleared of all vrf stuff.
hello again... sorry on the delay....
anywhere, i try to config it without vrfs:
interface ATM3/0/0
description FORWARDING_DIALER_05
no ip address
ip flow ingress
pvc 8/48
pppoe-client dial-pool-number 5
interface Dialer5
description Phone: ###########
ip address negotiated
ip mtu 1492
ip nbar protocol-discovery
ip flow ingress
encapsulation ppp
ip route-cache flow
dialer pool 5
dialer-group 5
ppp pap sent-username ########### password 0 ##########
but it's still not working. it is even not trying to create a session with the other side...
For sure you're missing "ip nat outside" in dialer interface.
Then check first if the interface is connected with "show dsl interface".
