Help needed for configuring BGP Multihoming
I need to configure BGP multihoming with two ISP using only one Router(L3 Switch with BGP). We have our own AS Number and a /24 IP Pool. We need to configure it as normal failover, we don't want to load balance between the two ISP links. We need ISP A to be the primary link through which all (IN & OUT) the traffics would pass through normally, and the ISP B  link would be used only if ISP A link fails.
ISP A should start handling the traffic again, as soon as the ISP A link becomes active.
Here is a Diagram of the Scenario :
Please help
19 Replies 19
Hello
Please review this below example:
The filter list 10 is to prevent your site becoming a transit path between either ISP
I have utilised the bgp weight attribute for preferred egress traffic and As-prepending for preferred ingress traffic
ip as-path access-list 10 permit ^$
route-map AS-Prpend permit 10
set as-path prepend 999 999 99
router bgp 999
neighbor x.x.x.x remote-as <ISP1>
neighbor x.x.x.x weight 40000
neighbor xx.x.x filter-list 10 out
 neighbor y.y.y.y remote-as <ISP21>
 neighbor y.y.y.y  weight 30000
 neighbor y.y.y.y filter-list 10 out
 neighbor y.y.y.y route-map AS-Prpend out
res
Paul
Kind Regards
Paul
Dear paul,
Thank you for the quick reply. I'll try it out and revert back asap.
Hello
Forgot to mention please ammend that example to fit your ASN numbering and peering addressing
res
Paul
Kind Regards
Paul
Hi paul,
Is the configuration sufficient or do i need to perform any other additional configuration?
Do i need to configure "ip prefix-list"
Hello
i have not see your existing configuration so cannot really comment- the example I gave would give you the prefer path and backup path to either ISP but  as far as any specific requirements that you already have I cannot say
The prefix command related to the bgp regular expression so to advertise only local routes to either ISP and to prohibit you site from becoming a transit path for either iISP.
res
paul
Kind Regards
Paul
Hi paul,
Here (attached) is the current config. Please take a look and help.
Hello
What i can establish is your excepting a deault route from a ISP and advertising one specific network
What i dont see is dual isp peering like what your topology diagram is showing So i guess this 2nd ISP is a forthcoming implementation?
res
Paul
Kind Regards
Paul
Yes, its forthcoming, only ISPA part is configured till now.
Hello
Please review the following example -
router bgp 999
neighbor Stan peer-group
neighbor Stan password xxx
neighbor x.x.x.x peer-group
neighbor y.y.y.y peer-group
neighbor x.x.x.x description ISP1
neighbor y.y.y.y remote-as <ISP2>
neighbor y.y.y.y description ISP2
maximum-paths 2
 address-family ipv4
 neighbor Stan route-map ISP-IN in
 neighbor Stan filter-list 10 out
 neighbor x.x.x.x activate
 neighbor y.y.y.y activate
 maximum-paths 2
 no auto-summary
 no synchronization
 network 1.1.1.0 mask 255.255.255.0
 exit-address-family
ip as-path access-list 10 permit ^$    <----- Advertised ONLY local routes
route-map AS-Prpend  <-- Prepend all local routes with local ASN to least prefferd ISP
set as-path prepend 999 999 999
ip prefix-list ISP1-IN permit 0.0.0.0/0
route-map ISP-IN permit 10 <-----------Allow only a  received Default from both ISP's
match ip address prefix-list ISP1-IN
res
Paul
Kind Regards
Paul
Thanks paul,
I'l test this over GNS3 asap.
Hello
Please note the changes I have made are regards adding Peer-groups and your exsitng outbound route-map -
res
Paul
Kind Regards
Paul
Hi paul,
Can you please tell what are these lines for?
I couldn't understand them.
Hello
Yes of course - neighbor xxx peer-group  - This is a peer group,its 3 of bgps different kinds of peer templates - ( this the basic one) -Which allows you share the same polices to multiple peers
In the configuration I supplied both your ISP peering will SHARE 3 polices -
password ( optional) - simple peering security between peers
filter-list 10   <---------- to negate transit traffci from ISP's
route-map ISP-IN in  <-------------- this is your exsitng route-map uou had to allow default route from the ISP
FYI -  The other 2 peering group templates you can uiltlze are
Peer Session
Peer Policy
But I didnt wont to convolute the posting with such configuration---
I hope this help - any other queires please dont hestitate is ask.
res
Paul
Kind Regards
Paul
Hi,paul
While configuring the line:
I get an error: % Invalid command for a peer-group member
I've attached current configuration for your reference.
Thanks for the help
