Help Needed - IPSEC from behind ADSL modem
I'm hoping you guys might be able to help me out.  I'm trying to set up an IPSec tunnel between 2 3845 routers that each sit in a private LAN behind an ADSL modem.  Each modem does have a static public IP address from the ISP.
Thus:
Cisco 3845-1 <-> ADSL modem <-> WAN <-> ADSL modem <-> Cisco 3845-2
3845-1
Gi 0/0 - private ip
         l
NAT
         l
ADSL modem/public IP
        l
WAN
        l
        l
NAT
        l
3845-2 GI 0/0 - private IP
So I would like to set up IPSEC between the GI 0/0 interfaces on the 3845's.
Any help that could be provided would be much appreciated.
Jon
Abzal
Level 7
Level 7
ADSL is performing a NAT translation I suppose. I don't know if this config works behind NAT device otherwise you will need to do port forwarding to routers.
Here is simple config:
3845-1:
crypto isakmp policy 2
authentication pre-share
crypto isakmp key cisco123 address 1.1.1.2
crypto ipsec transform-set Router-IPSEC esp-3des esp-sha-hmac
crypto map VPN_MAP 1 ipsec-isakmp
set peer 1.1.1.2                       // Public IP ADSL modem
set transform-set Router-IPSEC
match address 100
interface FastEthernet0/0
description Link to ADSL
ip address 192.168.2.2 255.255.255.252
crypto map VPN_MAP
interface FastEthernet0/1
description Link to LAN
ip address 10.20.10.1 255.255.255.0
ip route 10.10.10.0 255.255.255.0 192.168.2.1
access-list 100 permit ip 10.20.10.0 0.0.0.255 10.10.10.0 0.0.0.255
3845-2:
crypto isakmp key cisco123 address 1.1.1.1
set peer 1.1.1.1                           // Public IP ADSL modem
match address 100
ip address 192.168.1.2 255.255.255.252
crypto map VPN_MAP
ip address 10.10.10.1 255.255.255.0
ip route 10.20.10.0 255.255.255.0 192.168.1.1
access-list 100 permit ip 10.10.10.0 0.0.0.255 10.20.10.0 0.0.0.255
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
