Help required in routing
danishsattar
I'm having trouble in routing for my WAN Link. here is my scenario.
We have got a new internet connection and trying to make a smooth transition to this new connection. We have two DIA circuits terminated on a single router. one is for communicating with remote site and other one is for Internet (This one is new).
Remote site DIA Information:
BGP Number: 65333
Local IP: 172.22.66.77
Remote IP: 172.22.66.76
We only have to pass a very specific traffic to this link. i.e. destination address: 10.130.0.0/16 subnet traffic.
current config:
router bgp 65333
 bgp log-neighbor-changes
 redistribute connected
 redistribute static
 neighbor 172.22.66.76 remote-as 65000
Internet DIA Information (New):
Customer IP Address: 94.95.96.97/32
Gateway: 94.95.96.96
We have 15 more public IP Address with default gate to our WAN IP address  i.e. 94.95.99.100-115
For Local Interfaces we have:
Interface 01: 10.111.112.7 (local network)
Interface 02: 94.95.99.101 (Firewall) New settings
Now the problem before new internet connection we didn't have to divide the traffic so all traffic was going through 172.22.66.76 IP address, but now we only want to send very specific traffic i.e. destination address: 10.130.0.0/16. rest via internet gateway. So BGP was doing it's job and no trouble at all.
how do we configure this kind of routing and What changes need to be made in configurations, i tried adding 94.95.96.96 as default route but no luck traffic still going through 172.22.66.76 interface.
show ip route 94.95.96.97
 Known via "bgp 65333", distance 20, metric 0
  Tag 65000, type external
  Last update from 172.22.66.76 03:45:29 ago
  Routing Descriptor Blocks:
  * 172.22.66.76, from 172.22.66.76, 03:45:29 ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 65000
      MPLS label: none
Hello
router bgp 65333
no auto summary (older iOS)
neighbour 172.22.66.76 remote-as 65000
network 172.22.66.77 mask 255.255.255.252
network 10.111.112.0 mask 255.255.255.248
network x.x.x.x (any other local subnet you wish remote site to see)
Ip route 10.111.112.0 255.255.255.248 gig0.0.2544 172.22.66.76
ip route 0.0.0.0 0.0.0.0 94.95.96.96
res
Paul
Kind Regards
Paul
14 Replies 14
Mark Malone
Are both of these links using BGP?
No only first one.
Your default static should work but your redistributing static routes and connected interfaces back into the BGP process locally , if you remove that your static default will work out the internet link for all destinations not known by the router
tried that one but it stop the traffic to destination 10.130.0.0/16 as well.
It should not do that since your router knows the path to this subnet through BGP , the default is only for traffic that the router has no path to so it does not get dropped, quick fix use PBR apply it to your internet link interface with an extended ACL anything coming from source of your lan going to destination of 10.130.0.0/16 set the next hop ip address as the BGP gateway this will make all traffic go out through internet link but redirect traffic for that subnet back to BGP circuit
When you remove the bgp redistribute statements and add the default route  , what does it show for the show ip route 10.130.0.0/16 in routing table and BGP table
Are you receiving a default route through BGP already from ISP
I can ping from router to that network but not from end systems.
I created following access list:
access-list 101 permit ip any 10.130.0.0 0.0.255.255
route-map RemoteSite, permit, sequence 20
  Match clauses:
    ip address (access-lists): 101
  Set clauses:
    ip next-hop 172.22.66.76
    interface GigabitEthernet0/0.2544
    ip default next-hop 172.22.66.76
  Policy routing matches: 0 packets, 0 bytes
Still same problem no ping from end hosts
Try apply route - map to Lan interface in ,  can you attach the show run as it is now the parts involved
Current configuration : 5011 bytes
! Last configuration change at 17:01:21 UTC Thu Jun 4 2015 by
version 15.4
 no ip address
 duplex auto
 speed auto
 description TO-RemoteSite
 encapsulation dot1Q 2544
 ip address 172.22.66.77 255.255.255.252
interface GigabitEthernet0/1
 description TO-Core-SW
 ip address 10.111.112.7 255.255.255.248
  ip policy route-map RemoteSite
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2.3823
 description To-WAN
 encapsulation dot1Q 3823
 ip address 94.95.96.97 255.255.255.254
interface GigabitEthernet0/0/0
 description Firewall-Connection
 ip address 94.95.99.101 255.255.255.240
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 no ip address
 shutdown
 duplex auto
 speed auto
router bgp 65333
 network 10.30.0.0 mask 255.255.0.0 //no difference if its here or not
route-map RemoteSite permit 20
 match ip address 101 156 100
 set ip next-hop 172.22.66.76
access-list 100 permit icmp any 10.30.0.0 0.0.255.255
access-list 101 permit ip any 10.30.0.0 0.0.255.255
access-list 156 permit tcp any 10.30.0.0 0.0.255.255
PS. For now WAN interfaces are down Administratively.
any one help??
which prefixes are you receiving from BGP?
IMHO, instead of configuring PBR, you should simply filter the BGP prefixes recieved permitting only those you want to route to through you BGP neighbor.
Best regards,
Milan
I did that as well. the main problem is if i remove redistribute static and connected command , clients cannot seem to access the remote network. this is what i have tried.
remove bgp add static route to remote network - Result - router can ping but not end clients
BGP without redistribute commands- Same result as above
PBR - Same result as above
inbound filtering for BGP  - same result as above
the main problem is the redistribute commands. i know there shouldn't be any for bgp but without those end clients are not able to communicate with remote network.
So what should i do.
well, you need to think in two ways:
1) You need to advertise you local subnets via BGP. Without that the remote site users will not be able to reach your site user subnets through the BGP backbone.
So you need to redistribute your directly connected and static routes (some of them at least) to BGP on your router.
2) You need to reach only some of the remote subnets via BGP backbone. That's why you need to filter prefixes received from your BGP neighbour and permit only those you want to reach via BGP.
Am I clearer now?
Best regards,
Milan
Hello
router bgp 65333
res
Paul
Kind Regards
Paul
danishsattar
Thanks it worked.
