Help setting up my network
Hi everyone,
I am attempting a hands on project to cement several concepts for my CCNA and my MCSA and i am stuck at a certain point. I am implementing this setup within my own network for added functionality and practice. Furthur more i will be using this setup as my lab.
Here is what i have going on:
ISP---Modem---Cisco 2800 Router---Catalyst 3560G Switch
connected to the switch is a Windows 2012 DHCP ADDS server and all of my client systems.
The intended goal is to make it so the Windows server supplies my DHCP addresses through 3 scopes
10.227.10.1 255.255.255.0 - 10.227.10.100 255.255.255.0
10.227.20.1 255.255.255.0 - 10.227.20.100 255.255.255.0
10.227.30.1 255.255.255.0 - 10.227.30.100 255.255.255.0
I want to split my switch into 3 vlans
Vlan10 - 10.227.10.1
Vlan20 - 10.227.20.1
Vlan30 - 10.227.30.1
I also need to program the router to so that it works with my modem and the switch in order to access the internet, basically i want to make it so when i try and access the internet from one of my client computers, everything goes through like it should.
The issue i am having is that i know bits and pices of it like for example i need to put the IP helper address on the vlans after i give them an ip address in order to forward the DHCP packets. But the problem is i do not have all the info i need to see the picture as a whole.
My question, is there a guide or walkthrough or can someone wip up a quick config that i can follow to acomplish what im trying to do? I learn best buy following someones instructions and working through them line by line.
Thanks for your help,
Donnie
aedamasceno
Donald,
What you need is to create a NAT. For that you plug your modem on port Fast 0/0 on your 2800. Configure the port like this:
interface fas 0/0
ip address dhcp
ip nat outside
no shutdown
Then you plug your switch on port Fas 0/1, and use this config:
int fas 0/1
no shutdown
int fas 0/1.10
encapsulation dot 10 [native] (if this will be your native vlan)
ip address 10.227.10.1 255.255.255.0
ip nat inside
interface fas 0/1.20
encapsulation dot 20
ip address 10.227.20.1 255.255.255.0
ip nat inside
interface 0/1.30
encapsulation dot 30
ip address 10.227.30.1 255.255.255.0
ip nat inside
Now configure static routes:
config t
ip route 0.0.0.0 0.0.0.0 fas 0/0
ip access-list extended DONALD
permit ip 10.227.10.0 0.0.0.255
permit ip 10.227.20.0 0.0.0.255
permit ip 10.227.30.0 0.0.0.255
now configure the overload
ip nat source list DONALD inteface fas 0/0 overload
Now go on your switch and configure:
conf t
vlan 10
exit
vlan 20
exit
vlan 30
exit
interface vlan 10
ip nat inside
exit
interface vlan 20
ip nat inside
exit
interface vlan 30
ip nat inside
exit
Configure your trunk port on switch:
conf t
interface fas x/x
switchport mode trunk
switchport trunk native vlan 10 (if you chose to use 10 as the native vlan on Router config)
Now configure your ports for phones and data:
conf t
int fas x/x
switchport host
switchport access vlan XX (where XX is the VLAN number for Data)
switchport voice vlan XX
Hi Donnie ,
 Below are the things you need to ensure , before you try to access internet from your Vlans 10 , Vlans 20,Vlan 30
1) DHCP scope with appropriate gateway, GW IP address must be your SVI interface IP address of your switch  , DNS server for your providers .
2) if you keep your DHCP server on VLAN 10 , use IP-helper address for another two vlan 20 & vlan 30
3) Use L3 connectvity between L3 switch to your router . Like 10.10.10.0/28 . Router with ip address 10.10.10.1 and on your L3 switch use one switch port as L3 port by (no switch port command ) or you can create SVI VLAN 100 and you can use as switch port as access port for VLan 100 , assign IP address either on L3 port or on SVI VLAN 10.10.10.2
4) Point Default route from your L3 Switch to your router ( ip route 0.0.0.0 0.0.0.0 10.10.10.1)
5) From your router point reverse point  for
Vlan 10 , Vlan 20, Vlan 30
ip route 10.227.10.0 255.255.255.0 10.10.10.2
ip route 10.227.20.0 255.255.255.0 10.10.10.2
ip route 10.227.30.0 255.255.255.0 10.10.10.2
6) Configuring PAT overloading to the interface connecting to your internet modem , along with IP nat inside and IP nat outisde command
Let me know if you need any help on this .
Sandy
aedamasceno
Donald,
interface fas 0/0
ip address dhcp
ip nat outside
no shutdown
int fas 0/1
no shutdown
int fas 0/1.10
ip nat inside
ip nat inside
interface 0/1.30
ip nat inside
config t
conf t
vlan 10
exit
vlan 20
exit
vlan 30
exit
interface vlan 10
ip nat inside
exit
interface vlan 20
ip nat inside
exit
interface vlan 30
ip nat inside
exit
conf t
interface fas x/x
conf t
int fas x/x
switchport host
Hi aedamasceno,
Just a few things i need to clarify
"Configure your trunk port on switch: conf t interface fas x/x switchport trunk encapsulation dot1q switchport mode trunk switchport trunk native vlan 10 (if you chose to use 10 as the native vlan on Router config)"
Just to make sure i am getting this part i am suppose to pick an interface on the switch that is connected to the routers fa 0/1 interface and i need to set that as a trunk port?
"Now configure your ports for phones and data:
conf t
int fas x/x
switchport host
switchport voice vlan XX"
And with these instructions the FAS x/x is the switch port that i picked to connect to the router correct?
