Help to find the throughput value of ,Cisco1950BR-SEC/K9, C891F-K9
please Help to find the throughput value of ,Cisco1950BR-SEC/K9, C891F-K9 routers
Mark Elsen
  - Start by looking at the datasheets for the devices and look for performance parameters L
                        https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-519930.html
                       https://www.cisco.com/c/dam/en/us/products/routers/1905-serial-integrated-services-router-isr/data_sheet_c78-598372.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Joseph W. Doherty
"Cisco1950"
Did you mean a 1905?
If so I could only find Cisco stating:  "The Cisco 1905 enables deployment in high-speed WAN environments with concurrent services enabled up to 10 Mbps."
For the 89x series, see:
BTW, Cisco recommendations are very conservative, depending on you traffic types, and your configuration, you might obtain more throughput (often in the range of 2x to 4x the above - but, understand, what you might obtain beyond the above chart's numbers, can be very variable [your mileage might vary]).
