HELP! Weird Problem With PIX 501
sarfarazkazi
Attached is the network diagram and Pix Configuration. We have data circuits for all our branches just installed. The problem is that the Pix just stops to ping the branch Office routers.
1. From the Pix can ping 192.168.1.2 & 1.3
2. From 192.168.1.2 & 1.3 can ping all the networks.
3. From the Pix cannot reach the branch routers.
Appreciate all your support.
Sarfaraz
the idea as follow
u have the static route configured corectly on ur PIX
on the ISP router u need static route point to each barnch offic network thorugh the isp ip u have
and u need a static route like
try the following line to the ISP router and try then try to pin
ip route 192.168.1.0 255.255.255.0 192.168.1.254
for returne traffic or traffic comeing from branch to ISP going to PIX
in ur ISP i have seen u done like
ip route 192.168.0.0 255.255.0.0 10.x.x.x
this include 192.168.1.0/25 so the traffic when wanna go to the PIX network will go back to the ISP and this is the problem u have
try to fix it based on the above directions
good luck
15 Replies 15
Marwan ALshawi
do the branch routers have route to the pix configured correctly ?
Dear marwan,
Attached is the configuration of the branch router.
Sarfaraz
i can see the problem is routing issue
one more question the ISP routers belong to u ? i mean u have its config ?
can u tell me the IP address of directly conected interfaces of ISP1 and the brach router u sent me to give u the right config
Dear Marwan,
Attached is the configuration of the HO router(isp1.txt) and the branch router (apbbr.txt)
Sarfaraz
ok
in ur diagram there is somthing missing
what are these IPs
10.250.3.1
10.250.17.2
can u tell me what connectivity between the ISP rote and the brantch routers and do u have the connection direcrctly from pix to ISP?
and on ur pix i see u have the interface with ip 192.168.1.254
and u have other interface on the pis has ip in the same subnet !!!!
sorry but i want to be aware about the network
The IPs are of the ISPs. My LAN range is (192.168.1.0/254) I am not well versed with Pix. This is how it is.. I am using these IPs from the range to route the branch subnets. It was working and then it stopped.
Pix IP- 192.168.1.254
ISP-1 router IP: 192.168.1.2
ISP-2 router IP: 192.168.1.3
I have attached the configuration of pix as well.
please
what these IPs represent
10.250.17.1
10.250.3.1
these IPs belong to the ISP backbone. They are /30 subnets for routing in their internal network. I have nothing to do their network.
please
10.250.17.1
10.250.3.1
I have already mentioned that the router belongs to ISP they are the ones who are routing it.
try to add the following line on ISP route
and let me know
No it doesnt work. From pix (1.254) i can ping (1.2). From (1.2) I can ping 2.1,3.1,4.1. But from the Pix I cannot ping 2.1,3.1 & 4.1
the idea as follow
good luck
yeah got it working now...thank u so much for your time and efforts..
Sarfaraz
