Help with 857W router
LBaroufNo1
I got myself a Cisco 857W router. I have configured it to initiate a connection on ATM0, and it connects, I can ping from the console websites as an example. I have set a DHCP and NATing. But it seems that the clients can't be routed to the internet. Not sure what I'm doing wrong.
Not sure if it makes it more complexe, but FastEthernet0 is connected to another router. But the problem is the same if I connect a computer to it, instead of the router. Ultimatly, I'd like to use my other router for the Wifi portion (I know, I know, it's a 857W that I have, but yet it's the other one that will be used for the wireless only).
Building configuration...
Current configuration : 2120 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$AWf.$Bvpoe21JARraJlzR0nvqH/
enable password ********
no aaa new-model
dot11 syslog
no ip routing
no ip dhcp use vrf connected
ip dhcp excluded-address 8.8.8.8
ip dhcp excluded-address 8.8.4.4
ip dhcp excluded-address 192.168.1.1
ip dhcp pool vlan1
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 8.8.8.8
no ip cef
username ****** privilege 15 password 0 ********
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
ip virtual-reassembly
no ip route-cache
no atm ilmi-keepalive
pvc 0/35
  pppoe-client dial-pool-number 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip nat inside
no ip route-cache
ip tcp adjust-mss 1452
shutdown
bridge-group 1
bridge-group 1 spanning-disabled
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname <username>
ppp chap password 0 <password>
ppp pap sent-username <username> password 0 <password>
ppp ipcp dns request
ppp ipcp route default
interface BVI1
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer0 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password <password>
login
scheduler max-task-time 5000
end
Any help will be greatly appreciated.
issue command
ip routing
add this also
ip route 0.0.0.0 0.0.0.0 dialer 0
Also
Int Vlan 1
no shut
*** Do Rate Helpful Posts***
Jawad
Jeff Van Houten
Level 5
Level 5
If you're not going to use the wireless, get rid of the bridging and do a no shut on vlan1.
issue command
ip routing
add this also
Also
Int Vlan 1
no shut
Jawad
Thanks, it does work for clients other than the router. I assigned a static IP to the router for it to work and all is good. I just wonder why it wouldn't get an IP by DHCP if it has a DHCP client? Strange to me, it work in the end.
Cheers and thank you!
