Help with BGP/AS number design
Hello group,
We are in the process of moving our network from NetVPN to AVPN. At our core location, we'll be running both for a period of time until all remote locations can be switched over. I'm configuring a router for our AVPN circuit and have questions about choosing an AS number. At the present, we have:
    1. A internet facing router with a AS number
    2. A WAN router with a AS number
    3. A core switch with a AS number
I know these devices were setup as they are to help us with internet access redundancy (we have another internet circuit in our remote, DR site). After we bring all locations onto the AVPN network, the existing WAN router will be removed. My question(s) is do I need to have a separate AS number for the new router? I have a general idea of what AS numbers are and what they do, but still not 100% clear about their use. It would help if someone could show me an example of AS numbers and how they're used. I can provide config info if needed.
Thanks in advance,
Chris
5 Replies 5
adnane dakna
is better to submit  you config routers with architecture network you're planning  to switch to.
I don't have access to the Internet router right now, but will try to post it shortly.
I'm not sure what to post for the 'architecture network you're planning  to switch to'. I've attached the new router, the current router and switch configs.
Giuseppe Larosa
Hello Chris,
as it happens for IP addresses there are public AS numbers and private AS numbers ( 64512 - 65535 for 16 bit AS numbers).
Public AS numbers are assigned by regional internet registries like ARIN, RIPE, APNIC and a few others.
Like public IPv4 address blocks public AS numbers are precious and some conditions have to be met to get one.
A public AS number is unique woldwide and it is assigned to a specific company, A public AS number may appear in public BGP internet tables as the source of some public IP address blocks belonging to your company (in the AS path BGP attribute that records all the ASes a prefix has been propagated through )
Again these public IP addresses are assigned by RIRs.
However, for VPN services customers like you are connected to, the use of private AS numbers is enough. A private AS numbers provide a non unique non global AS number just to be used to setup eBGP sessions with the ISP. In this case the ISP will handle the private AS number in such a way that the private AS number is removed before propagating customer routes to the internet.
The private AS number is assigned to you by the ISP or agreed with them
It is likely that all your devices are using private AS numbers, The new AVPN service can re-use the same AS number or  it can use a new one.
Hope to help
Giuseppe
Thanks, Giuseppe!
Don't know why my txt file was seen as a virus, but here's the contents of the three files attached..
WAN Router
! Last configuration change at 14:12:35 EST Wed Jan 9 2013 by wjerrell
! NVRAM config last updated at 14:02:34 EST Wed Jan 9 2013 by wjerrell
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname RT00-2811-01
boot-start-marker
boot-end-marker
logging buffered 32000 debugging
no logging console
no logging monitor
enable secret 5 $1$Uj7n$/gpiBefkWvQI2iwOPfoe7.
no aaa new-model
clock timezone EST -5
clock summer-time EST recurring
ip wccp web-cache redirect-list 120
ip cef
ip flow-cache timeout active 1
no ip bootp server
no ip domain lookup
ip domain name secfedbank.com
ip name-server 205.152.226.254
ip name-server 205.152.0.5
ip sla monitor 1
type echo protocol ipIcmpEcho 10.45.45.1 source-interface FastEthernet0/0.10
ip sla monitor schedule 1 life forever start-time now
voice-card 0
no dspfarm
crypto pki trustpoint TP-self-signed-2105432603
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2105432603
revocation-check none
rsakeypair TP-self-signed-2105432603
crypto pki certificate chain TP-self-signed-2105432603
certificate self-signed 01
  30820253 308201BC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32313035 34333236 3033301E 170D3038 30353231 30323136
  31365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 31303534
  33323630 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B35A 3AB46162 379144AE 24923FA4 BC263CEF EE6956E9 0BAD15EC 428795FE
  6CD29BF5 453D0D2B 223BAAC9 C7737337 7CB8A3FB 4F46CC4B 81391004 F218159D
  BAD172A9 1F13747F 89F32806 583B9F8C C6BE72CF E02393A9 52B6ED2E C7002A6A
  CB33B650 5A965B69 F21345A3 E99A1F06 D6DDF77D 5E18EBCD F955B3A8 3BA151B2
  A0090203 010001A3 7B307930 0F060355 1D130101 FF040530 030101FF 30260603
  551D1104 1F301D82 1B525430 302D3238 31312D30 312E7365 63666564 62616E6B
  2E636F6D 301F0603 551D2304 18301680 142ACDDC 6AF8C469 E5D285AF DEEAA249
  383B80B5 17301D06 03551D0E 04160414 2ACDDC6A F8C469E5 D285AFDE EAA24938
  3B80B517 300D0609 2A864886 F70D0101 04050003 81810042 54F8188B 8EBDA319
  C0B76D85 AD4F05F1 5804BD0B 19EB6C72 11575565 FC4F61FA 7D80D2FA 20A3565E
  C19C5903 FCB215D4 CBAB12F6 4D4A4D35 29D5AD58 72112742 3912E23D 3C36D386
  F6D81943 F37A5C5F 36146C78 328EB9E3 2839C466 B5DEBF8F 696B0C8A BE001E36
  B34D06C8 E725CED4 E9D5C953 30C702B4 39479E68 CC8568
  quit
ip ssh version 2
track 1 rtr 1 reachability
class-map match-any Business_Ingress
match access-group 130
class-map match-any Business_Data
match ip dscp af21
class-map match-any ATM_Traffic
match access-group 140
class-map match-any Voice
match  dscp ef
match access-group name Voice-Traffic
class-map match-any Replication
match access-group 150
class-map match-any Voice_Ingress
policy-map Voice-Traffic
class Voice
  priority percent 15
class Business_Data
  bandwidth percent 64
class Replication
    police 7000000
class ATM_Traffic
  priority percent 5
class class-default
policy-map WAN_QOS
class class-default
  shape average 10000000
  service-policy Voice-Traffic
policy-map QOS_INGRESS_LAN
class Business_Ingress
  set ip dscp af21
class Voice_Ingress
  set ip dscp ef
no ip address
ip flow ingress
ip flow egress
ip route-cache flow
duplex auto
speed auto
mpls netflow egress
service-policy input QOS_INGRESS_LAN
description Data Network
encapsulation dot1Q 10
ip address 10.20.102.10 255.255.255.0
no ip redirects
ip accounting output-packets
ip wccp web-cache redirect in
ip flow ingress
interface FastEthernet0/0.100
description SAN Replication
encapsulation dot1Q 4
ip address 10.20.100.10 255.255.255.0
no ip redirects
ip flow ingress
interface FastEthernet0/0.104
encapsulation dot1Q 104
ip address 10.20.104.10 255.255.255.0
no ip redirects
ip flow ingress
interface FastEthernet0/0.172
description Voice Network
encapsulation dot1Q 172
ip address 172.20.102.2 255.255.255.0
ip helper-address 10.20.102.4
ip helper-address 10.20.102.5
no ip redirects
ip flow ingress
ip flow egress
no cdp enable
interface FastEthernet0/1
no ip address
duplex full
speed 100
interface FastEthernet0/1.22
description Operations - AT&T - 42.KQGN.400006
bandwidth 10000
encapsulation dot1Q 22
ip address 192.168.0.102 255.255.255.252
no ip redirects
ip nbar protocol-discovery
ip flow ingress
service-policy output WAN_QOS
router bgp 65342
bgp log-neighbor-changes
neighbor 10.20.100.1 remote-as 2388
neighbor 10.20.102.1 remote-as 2388
neighbor 10.20.104.1 remote-as 2388
neighbor 192.168.0.101 remote-as 6389
address-family ipv4
  neighbor 10.20.100.1 activate
  neighbor 10.20.102.1 activate
  neighbor 10.20.104.1 activate
  neighbor 192.168.0.101 activate
  no auto-summary
  no synchronization
  network 10.15.1.0 mask 255.255.255.0
  network 10.20.100.0 mask 255.255.255.0
  network 10.20.102.0 mask 255.255.255.0
  network 10.20.104.0 mask 255.255.255.0
  network 10.79.104.0 mask 255.255.255.0
  network 10.255.102.0 mask 255.255.255.0
  network 172.20.102.0 mask 255.255.255.0
  network 192.168.0.100 mask 255.255.255.252
exit-address-family
ip forward-protocol nd
ip route 10.15.1.0 255.255.255.0 10.20.102.125 track 1
ip route 10.15.1.0 255.255.255.0 10.20.128.16 100
ip route 10.20.10.0 255.255.255.0 10.20.102.195
ip route 10.45.45.1 255.255.255.255 10.20.102.125 10
ip route 10.45.45.1 255.255.255.255 10.20.128.16 20
ip route 10.79.0.0 255.255.0.0 10.20.102.195
ip route 10.79.104.0 255.255.255.0 10.20.102.195
ip route 10.100.102.0 255.255.255.0 10.20.128.10
ip route 170.209.0.2 255.255.255.254 10.20.102.12
ip route 170.209.0.2 255.255.255.255 10.20.102.12 permanent
ip route 170.209.0.3 255.255.255.255 10.20.102.12 permanent
ip route 192.168.0.0 255.255.255.0 192.168.0.101
ip route 208.61.216.1 255.255.255.255 10.20.102.195
ip flow-export source FastEthernet0/1.22
ip flow-export version 9
ip flow-export destination 10.20.102.15 2055
ip flow-top-talkers
top 20
sort-by bytes
cache-timeout 30000
ip http server
ip http authentication local
no ip http secure-server
ip access-list extended Voice-Traffic
permit udp 172.20.0.0 0.0.255.255 any eq 2427
permit udp 172.20.0.0 0.0.255.255 any eq 2727
permit udp 172.20.0.0 0.0.255.255 any range 5440 5446
permit ip 172.20.0.0 0.0.255.255 any dscp ef
logging trap debugging
logging facility local2
logging 10.20.102.20
access-list 5 permit 0.0.0.0
access-list 6 permit 208.61.216.1
access-list 7 permit 10.15.1.0 0.0.0.255
access-list 10 permit 0.0.0.0
access-list 10 permit any
access-list 20 permit 10.20.102.22
access-list 100 permit ip 10.20.102.0 0.0.0.255 any
access-list 100 deny   ip any 170.209.0.2 0.0.0.1
access-list 100 permit ip any any
access-list 120 deny   ip host 10.20.102.22 any
access-list 120 permit ip host 10.20.102.89 any
access-list 120 deny   ip any any
access-list 127 deny   ip host 10.20.102.51 host 205.152.226.254
access-list 127 deny   ip host 10.20.102.51 host 205.152.0.5
access-list 127 permit ip host 10.20.102.51 any
access-list 127 deny   ip host 10.20.102.52 host 205.152.226.254
access-list 127 deny   ip host 10.20.102.52 host 205.152.0.5
access-list 127 permit ip host 10.20.102.52 any
access-list 127 deny   ip any any
access-list 130 deny   ip 10.20.100.0 0.0.0.255 any
access-list 130 deny   ip host 10.20.102.8 any
access-list 130 deny   ip host 10.20.102.154 any
access-list 130 deny   ip host 10.20.102.23 any
access-list 130 permit ip 10.20.0.0 0.0.255.255 10.20.0.0 0.0.255.255
access-list 140 permit ip any host 10.20.105.254
access-list 140 permit ip any host 10.20.110.254
access-list 140 permit ip any host 10.20.112.254
access-list 140 permit ip any host 10.20.114.254
access-list 140 permit ip any host 10.20.117.2
access-list 140 permit ip any host 10.20.118.254
access-list 140 permit ip any host 10.20.122.254
access-list 140 permit ip any host 10.20.124.254
access-list 140 permit ip any host 10.20.128.254
access-list 140 permit ip any host 10.20.126.254
access-list 140 permit ip any host 10.20.134.254
access-list 140 permit ip any host 10.20.132.254
access-list 140 permit ip any host 10.20.140.254
access-list 140 permit ip any host 10.20.142.254
access-list 150 permit ip 10.20.100.0 0.0.0.255 any
access-list 150 permit ip host 10.20.102.8 any
access-list 150 permit ip host 10.20.102.23 any
access-list 150 permit ip host 10.20.102.154 any
snmp-server community sfbnet RO
snmp-server enable traps envmon
snmp-server enable traps voice poor-qov
snmp-server host 10.20.102.15 sfbnet
snmp-server host 10.20.102.21 sfbnet
route-map ADV_ROUTES permit 10
match ip address 7
route-map Set_Local_Pref permit 10
match ip address 10
set local-preference 120
set community 418709624
route-map Check-Internet permit 10
match ip address 5
match ip next-hop 6
control-plane
banner motd ^C
banner motd ^C
THIS SYSTEM IS FOR THE USE OF AUTHORIZED USERS ONLY!  INDIVIDUALS USING
THIS COMPUTER SYSTEM WITHOUT AUTHORITY, OR IN EXCESS OF THEIR AUTHORITY,
ARE SUBJECT TO DISCIPLINARY ACTION.  ANYONE USING THIS SYSTEM EXPRESSLY
CONSENTS TO MONITORING. BY ACCESSING THIS SYSTEM, YOU ARE ACCEPTING
RESPONSIBILITY FOR ALL OF YOUR ACTIONS.  THIS SYSTEM IS THE PROPERTY OF
SECURITY FEDERAL BANK.
^C^C
line con 0
password 7 133C4F5C3C582E0E7F
login
line aux 0
password 7 071C244F1D0C4A
line vty 0 4
password 7 152B5342137E21207C
login local
transport input ssh
transport output ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
ntp clock-period 17180045
ntp server 208.61.216.1
end
End WAN Router
Core Switch
! Last configuration change at 11:52:39 EST Thu Jan 31 2013 by chall
! NVRAM config last updated at 11:52:40 EST Thu Jan 31 2013 by chall
version 12.2
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
hostname sw00-3560-01
boot-start-marker
boot-end-marker
logging buffered 32000 warnings
no logging console
enable secret 5 $1$Evs8$nsd7tSGp6asz4z.Fm9jbW.
no aaa new-model
clock summer-time EDT recurring
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
ip routing
router bgp 2388
neighbor 10.20.102.10 remote-as 65342
neighbor 208.61.216.1 remote-as 2386
neighbor 208.61.216.1 ebgp-multihop 3
neighbor 208.61.216.1 update-source Vlan1
address-family ipv4
  neighbor 10.20.102.10 activate
  neighbor 10.20.102.10 default-originate route-map Check-Internet
  neighbor 208.61.216.1 activate
  neighbor 208.61.216.1 prefix-list 10 out
  no auto-summary
  no synchronization
  network 10.20.10.0 mask 255.255.255.0
exit-address-family
ip classless
ip route 0.0.0.0 0.0.0.0 10.20.102.10 201
ip route 10.20.11.0 255.255.255.0 10.20.102.10
ip route 10.255.128.0 255.255.255.0 10.20.102.10
ip route 172.16.1.0 255.255.255.224 10.20.128.10
ip route 192.168.0.0 255.255.248.0 10.20.102.10
ip http server
ip prefix-list 10 seq 1 deny 10.20.0.0/16
ip prefix-list 10 seq 2 deny 172.20.0.0/16
ip prefix-list 11 seq 1 deny 208.61.216.0/24
ip sla enable reaction-alerts
access-list 10 permit 10.20.0.0 0.0.255.255
access-list 10 permit 172.20.0.0 0.0.255.255
match ip address 5
match ip next-hop 6
snmp-server location Ops
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps errdisable
snmp ifmib ifindex persist
banner motd ^C
^C
line con 0
line vty 0 4
login local
length 0
line vty 5 15
login local
ntp clock-period 36029059
ntp server 10.20.102.10
end
End core switch
New Router
SH RUN
Building configuration...
Current configuration : 3098 bytes
version 12.4
hostname RT00-2811-02
boot-start-marker
boot-end-marker
no logging console
no logging monitor
no aaa new-model
ip cef
no ip bootp server
no ip domain lookup
ip sla monitor 1
voice-card 0
no dspfarm
ip ssh version 2
no ip address
shutdown
duplex auto
speed auto
ip address 10.20.102.110 255.255.255.0
no ip redirects
no ip proxy-arp
ip flow ingress
no cdp enable
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1.436
description AT&T 42.KQGN.600265.SB
bandwidth 20000
encapsulation dot1Q 436
ip address 192.168.0.90 255.255.255.252
no ip redirects
no ip proxy-arp
ip flow ingress
no cdp enable
interface Serial0/0/0
no ip address
shutdown
ip http server
control-plane
line con 0
login
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
RT00-2811-02#
End New Router
