Help with Cisco 3750X transporting 2nd ISP via Fiber. Is it possible?
DreDoubleU
         Please bare with me as I don't have my CCNA yet. But I am being asked about the possibility of transporting a 2nd Internet connection (in efforts to save money on hardware) through our existing switches. In this building for example, a 3750X is handling layer 3, and two other 3750's are staggered through the building. This building wants a public connection they pay for themselves, and we don't want that traffic in our core EIGRP based network anyway. I have Metro Ethernet providing connection through copper to port 48, and then we are trunking out via fiber to the other switches in the building. Is there anyway I could bring the new fiber public connection in through another gbic, ride the fiber and shoot it down to the furthest switch away and spit it back out? Pretty much we cant afford to buy a new router, do a new run, etc. I dont know if I'm over complicating this for myself, or what. I'm sorry if this is confusing. would I just have to create its own pool and vlan? example?For Instance.jpg
is this switch already connected to a primary ISP ? I am just asking because I do not see any NAT configuration.
Either way, here is the rudimentary approach. I assume that the new Vlan is 99, and the IP address space used is 192.168.1.0/24. The extended access list used in the route map denies all traffic that goes to the other Vlans, which means you have to add the correct addresses and probably have to add more lines, since you have more Vlans).
access-list extended VLAN99 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list extended VLAN99 deny ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list extended VLAN99 permit ip 192.168.1.0 0.0.0.255 any
access-list 99 permit 192.168.1.0 0.0.0.255
route-map VLAN99_TO_ISP2
match ip address VLAN99
set ip next-hop x.x.x.x
interface Vlan99
ip policy route-map VLAN99_TO_ISP2
ip nat inside source list 99 interface GigabitEthernetx/x overload
10 Replies 10
akumarka
create a separate vlan for new link .
hope link between switches are trunks . dual links are not needed if interconnect links are trunks
allow new vlan created through trunks between switches .assign new 24p switch to new vlan
As in
interface GigabitEthernet1/1/1
 description *** ***
 switchport mode access vlan (new)
etc?
yes and pass this new vlan over trunk ,and assign new vlan to access ports of new switch
 Is this on the right Track?
 I am sorry for all the questions, I just cant find anything that I can make sense of in my searches
interface GigabitEthernet1/1/2                         <Switch 1
description *** ***
switchport mode access vlan 99
interface Vlan99
ip address ??.??.??.?? 255.255.255.0 etc
interface GigabitEthernet1/1/3                             <Switch 3
description *** ***
switchport mode trunk
interface GigabitEthernet1/1/1                              < New 24P Switch
description *** ***
Interface GigabitEthernet 1/0/1
switchport access vlan 99
spanning tree portfast
etc
hoping that 1/1/2 is uplink
trunk between sw1 -- sw2 ---sw3 already there
1/1/1 is downlink for new switch in sw3 ..
1/0/1 is up link in new switch , yes correct
if you successfully manage to trunk the new VLAN to the 3750x, yes, create a VLAN 99 interface on the 3750x. You then need to policy route traffic for the VLAN out the new connection. The entire setup is actually fairly easy to achieve.
If you post the configuration of the 3750x, we can add the necessary bits and pieces...
will shortly
This is the head end switch. The other two are similar, each has gig modules with atleast two gbics available for fiber. Thank you guys for being patient, I appreciate it.
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname 3750X
boot-start-marker
boot-end-marker
enable secret 5
enable password 7
username
username
aaa new-model
aaa authentication login default group tacacs+ local enable
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 15 default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa session-id common
clock timezone MST7 -7 0
switch 1 provision ws-c3750x-48p
system mtu routing 1500
ip routing
no ip gratuitous-arps
ip dhcp bootp ignore
ip dhcp excluded-address etc
ip dhcp pool
network ******* *******
dns-server ******* *******
domain-name *******
netbios-name-server ******* *******
netbios-node-type h-node
default-router *******
option 156 ascii ftpservers=*******,country=1,language=1,layer2tagging=1,vlanid=3
ip dhcp pool camera
network ******* 255.255.255.0
domain-name *******
ip dhcp pool *******
domain-name *******
option 4 ip *******
domain-name *******
netbios-name-server ******* 1*******
no ip domain-lookup
ip domain-name *******
ip multicast-routing distributed
ip multicast cache-headers
ip multicast multipath
login block-for 20 attempts 2 within 30
login delay 2
login on-failure log
login on-success log
mls qos map policed-dscp 0 10 18 24 46 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
crypto pki trustpoint TP-self-signed-902053632
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-902053632
revocation-check none
rsakeypair TP-self-signed-902053632
crypto pki certificate chain TP-self-signed-902053632
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
license boot level ipservices
spanning-tree mode pvst
auto qos srnd4
vlan internal allocation policy ascending
ip ssh authentication-retries 4
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
set dscp ef
police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
set dscp cs3
police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
set dscp default
police 10000000 8000 exceed-action policed-dscp-transmit
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
switchport voice vlan 3
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
switchport voice vlan 2
srr-queue bandwidth share 1 30 35 5
srr-queue bandwidth shape 10 0 0 0
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
power inline never
interface GigabitEthernet1/0/26
power inline never
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
no switchport
bandwidth 100000
ip address ******* 255.255.255.0
ip pim sparse-dense-mode
priority-queue out
mls qos trust cos
auto qos trust
shutdown
interface GigabitEthernet1/1/4
shutdown
interface TenGigabitEthernet1/1/1
shutdown
interface TenGigabitEthernet1/1/2
shutdown
interface Vlan1
interface Vlan2
description cisco
interface Vlan3
interface Vlan4
description *******
interface Vlan70
description *******
interface Vlan80
description timeclock
router eigrp 24
network *******
network *******
network *******
network *******
passive-interface default
no passive-interface Vlan1
no passive-interface Vlan2
no passive-interface Vlan3
no passive-interface Vlan4
no passive-interface GigabitEthernet1/1/1
no passive-interface GigabitEthernet1/1/2
no passive-interface GigabitEthernet1/1/3
no passive-interface GigabitEthernet1/1/4
no passive-interface Vlan70
no passive-interface Vlan80
no passive-interface GigabitEthernet1/0/48
eigrp stub connected summary
ip default-gateway *******
no ip http server
ip http secure-server
logging esm config
logging trap debugging
logging *******
logging *******
snmp-server community *******
snmp-server location *******
snmp-server contact *******
tacacs-server host *******
tacacs-server key 7 *******
banner motd ^CC
* L E G A L N O T I C E -- Y O U M U S T R E A D *
* You must have explicit permission to access or configure this *
* device. All activities performed on this device are logged and *
* violations of this policy may result in criminal prosecution. *
* This system is for the use of authorized users only. Individuals using *
* this computer system without authority, or in excess of their authority,*
* are subject to having all of their activities on this system monitored *
* and recorded by system personnel. *
* Anyone using this system expressly consents to such monitoring and is *
* advised that if such monitoring reveals possible evidence of criminal *
* activity, system personnel may provide the evidence of such monitoring *
* UNAUTHORIZED ACCESS TO THIS NETWORK DEVICE IS PROHIBITED *
***************************************************************************^C
line con 0
privilege level 15
password 7 07242E6741191C091B1B595E
logging synchronous
line vty 0 4
exec-timeout 2 0
privilege level 15
password 7 080A43650609001B1E025E56
logging synchronous
length 0
transport input ssh
line vty 5 15
exec-timeout 2 0
privilege level 15
logging synchronous
length 0
transport input ssh
end
interface Vlan99
I'm not well versed in ACL's yet,
So assuming these addresses below apply to the following vlans
Vlan 1 172.24.211.1
Vlan 2 10.50.211.1
Vlan 3 10.100.211.1
Vlan 4 10.200.211.1
Vlan 70 10.80.211.1
Vlan 80 100.80.211.1
Vlan 99 172.25.211.1
access-list extended VLAN99 deny ip 172.24.0.0 0.0.0.255
access-list extended VLAN99 deny ip 10.0.0.0 0.0.0.255
access-list extended VLAN99 permit ip 172.25.0.0 0.0.0.255 any
access-list 99 permit 172.25.0.0 0.0.0.255
interface Vlan99
ip address 172.25.211.1 255.255.255.0
ip nat inside source list 99 interface GigabitEthernet1/1 overload
what is best practice to segregate all that other traffic in their own ACL's? create another list with permit any any? Thank you for being so helpful, I will mark this answered and figure out the rest. My environment is kind of tough to test in, as all of the gear is live, I have no dual connections anywhere, and we cant afford training. So I do appreciate you going out of your way, this is my first time on the site, and I'm blown away by the help people offer others.
