Help with Cisco 897 Router
Karakas
I connect my ISP provided ONT directly to the wan port on the cisco 897 and I can't access internet. I don't know if its my configuration or such or if it is my ISP. Can someone please give me some advice on what to do because I am pretty new to cisco CLI and cisco routers in general.
Thank you
18 Replies 18
@Karakas
 When you say you can not connect I am assuming you are plugging a computer behind those devices and testing. Then some questions arise.
 Does the PC gets IP address?
Does the PC gets DNS server?
Can you ping 8.8.8.8?
Do you have NAT on the 897?
Do you have  ACL (access list) ?
Yes I get local ipv4 ip addresses , the pc does not get a dns server when I am plugged directly through the cisco router, I cannot ping 8.8.8.8, I do have NAT on and I am not sure about the access list
If you are receiving a public IP from the ISP, you need NAT on the router.
Can I see the output of "show ip route" ?
Here it is:
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan1
L 192.168.1.1/32 is directly connected, Vlan1
I saw the router config down below. The problem seems to be related to NAT. On the configuration for interface GigabitEthernet8. you need to add the command "ip nat outside"
description PrimaryWANDesc_
mac-address 7406.3513.7850
ip address dhcp
ip tcp adjust-mss 1412
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 2
ip nat outside
I did that but unfortunately still no connection
My gigabitethernet 8 interface doesn't appear to pull any ip's
If your interface is not pulling any IP that could be an ISP problem.
The NAT config must be there, that´s for sure. Now, you need to get an IP address on that interface. If you connection method is really PPOE, I would recommend you to see the following video
https://www.youtube.com/watch?v=W3einvpbxCU
Watched the video wrote the commands one by one and configured it exactly the same I even did a router restart still no ip tho
It is connected to an ISP, right? If so, I would given them a call
I would give them a call but nothing will possibly change.
Isn't there any way I can bypass this somehow?
Maybe an sfp module or something.
I dont know the environment out there. If you have a ISP and they can provide you only the PPPOE method, It is hard to believe there will be another way.
If they can provide you another access method, then things change. Here
Stray_Bullet
We would definitely have to see your configuration as it could be anything.
here is my configuration:
Current configuration : 5499 bytes
version 15.4
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.1.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.128
default-router 10.10.10.1
lease 0 2
ip dhcp pool vodafonerouter
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip domain list station
no ip domain lookup
ip domain name yourdomain.com
ip cef
ipv6 unicast-routing
ipv6 cef
cts logging verbose
license udi pid C897VAB-K9 sn FCZ2229E352
username karakas privilege 15 secret 5 $1$iVDC$yblI9dlOZhJq5dD/DO1Bb1
controller VDSL 0
no cdp run
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
interface GigabitEthernet0
no ip address
duplex full
speed 1000
spanning-tree portfast
interface GigabitEthernet1
no ip address
duplex full
speed 1000
interface GigabitEthernet2
no ip address
duplex full
speed 1000
interface GigabitEthernet3
no ip address
duplex full
speed 1000
interface GigabitEthernet4
no ip address
duplex full
speed 1000
interface GigabitEthernet5
no ip address
duplex full
speed 1000
interface GigabitEthernet6
no ip address
duplex full
speed 1000
interface GigabitEthernet7
no ip address
duplex full
speed 1000
ip address dhcp
duplex auto
speed auto
interface Vlan1
description $ETH_LAN$
ip nat inside
ip virtual-reassembly in
ipv6 address autoconfig
ipv6 enable
interface Dialer1
ip address dhcp
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
no cdp enable
interface Dialer2
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 2
dialer-group 2
ppp mtu adaptive
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet8 overload
ip nat inside source list nat-list interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
tftp-server flash:/firmware/vdsl_bond.bin
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
