Help With Cisco Packet Tracer Assignment
mvwebb88
Hello! I am new to Cisco and could really use some help with completing this assignment. This will help guide me with future assignments and getting more knowledge of how this program works! Thank you in advance. I am currently using the 6.2 version.
9 Replies 9
post your zipped Packet Tracer project (.pkt) file with what you have configured so far...
mvwebb88
Hi Georg!
Here you go.
thanks for posting. I'll have a look...
I opened your file, but it is basically an empty project with nothing configured. Completing the entire project will take at least several hours. What kind of support/help do you get ? And what is your experience level ?
hey george, can u help me with my assignment?
Hi Georg!
The only support I have is my textbook. I will reattempt and upload a more completed file tomorrow.
Hi Georg,
Please see my zip file that I started configuring. I ran into an issue. The first LAN will not ping? Do I need to wait until all configuration is complete? Also, I cannot configure the second LAN. I cannot figure out a correct IP address. I have attached screenshots with my solutions as well as the pkt file
below are the configs for the LAN on the left side. The two routers in the middle need an additional layer 3 interface, so you have to add that.
Switch#wr
Building configuration...
[OK]
Switch#sh run
Current configuration : 1191 bytes
version 12.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
switchport mode trunk
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Marianne_Webb_R1#sh run
Current configuration : 1109 bytes
version 12.4
hostname Marianne_Webb_R1
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp pool VLAN_10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool VLAN_20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip cef
no ipv6 cef
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip address 172.16.12.1 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router rip
version 2
network 172.16.0.0
no auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Leo Laohoo
Move this Packet Tracer homework to the Cisco Learning Network.
https://learningnetwork.cisco.com/s/topic/0TO6e000000WEorGAG/packet-tracer
