Help with EIGRP and 2 routers.
V3teran75
I need help with this connection as i cannot get it to work even when i have entered the correct commands or so i think i have.
I cannot get the routers EDGE and REMOTE to PING each other. When i configured frame relay they worked fine. But when i setup EIGRP it stopped them from communicating. Can anyone help please ive been at this for around 8 hours now and im about to give up as i dont know were else to turn.
Im getting this error also know when i setup EIGRP on both routers
%DUAL-5-NBRCHANGE: IP-EIGRP 100: Neighbor 205.100.80.2 (Serial0/2/0) is down: retry limit exceeded
%DUAL-5-NBRCHANGE: IP-EIGRP 100: Neighbor 205.100.80.2 (Serial0/2/0) is up: new adjacency
Here are the IP addresses
Please help
Paul,
You have an incorrect mapping on the remote router:
Edge:
Serial0/2/0 (up): ip 205.100.80.2 dlci 102, static, broadcast, CISCO, status defined, active
Remote:
Serial0/0/0 (up): ip 200.100.80.1 dlci 201, static, broadcast, CISCO, status defined, active
On the remote router, remove your mapping and add this:
int s0/0/0
no frame-relay map ip 200.100.80.1 201 broadcast
frame-relay map ip 205.100.80.1.2 201 broadcast
That should fix it...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
13 Replies 13
John Blakley
Please post the configs of the Edge and remote routers...
HTH,
John
Jon Marshall
Paul
Can you ping between the routers ?
Can you post the EIGRP config from both routers ?
Jon
V3teran75
EDGE Router Config
Router#sho
Router#show ru
Router#show running-config
Building configuration...
Current configuration : 950 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip ssh version 1
spanning-tree mode pvst
interface FastEthernet0/0
ip address 200.100.90.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 172.18.20.10 255.255.255.252
clock rate 64000
interface Serial0/0/1
no ip address
shutdown
interface Serial0/2/0
bandwidth 64
ip address 205.100.80.1 255.255.255.252
encapsulation frame-relay
frame-relay map ip 205.100.80.2 102 broadcast
interface Serial0/2/1
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 100
network 172.18.20.0 0.0.0.255
network 205.100.80.0 0.0.0.3
auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router#
REMOTE Router config
Router#
Router#
Router#show
Router#show ru
Current configuration : 846 bytes
version 12.4
hostname Router
ip ssh version 1
ip address 172.18.24.1 255.255.255.0
duplex auto
speed auto
ip address 205.100.100.2 255.255.255.252
duplex auto
speed auto
bandwidth 64
ip address 205.100.80.2 255.255.255.252
frame-relay interface-dlci 201
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 100
auto-summary
ip classless
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
Router#
%DUAL-5-NBRCHANGE: IP-EIGRP 100: Neighbor 205.100.80.1 (Serial0/0/0) is down: retry limit exceeded
%DUAL-5-NBRCHANGE: IP-EIGRP 100: Neighbor 205.100.80.1 (Serial0/0/0) is up: new adjacency
Paul,
You're missing your dlci on interface Serial0/2/0 on your edge router. Can you put "frame-relay interface-dlci 102" under that interface and try again?
HTH,
John
Sorry for not being that good as Cisco but how do i actually do that, my brain has had it today after 9 hours of this.
Under your edge router:
int s0/2/0
frame-rela interface-dlci 102
HTH,
John
V3teran75
Ok i did that before you actually posted but thanks for helping as i requested.
Anyhow here are my configs again and i still cannot ping from EDGE to REMOTE
I have also attached my packet tracer file to my original thread starting post if anybody would like to take alook at it for me please. I have a serious headache after 11 hours trying to get this to work. I have to go to bed now as i can hardly look at the screen anymore. Thankyou for helping.
EDGE
Router#show run
Current configuration : 982 bytes
version 12.4
hostname Router
ip ssh version 1
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
clock rate 64000
no ip address
shutdown
bandwidth 64
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 100
auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router#
REMOTE
Router#en
Router#enable
Router#show
Router#show ru
version 12.4
hostname Router
ip ssh version 1
duplex auto
speed auto
duplex auto
speed auto
bandwidth 64
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 100
auto-summary
ip classless
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
Router#
How do you have your frame-relay switch set up? The port that the edge router connect to needs to have a mapping for port 102 and the remote router port should be configured for 201. I can't tell from your pic above if that's the case. Otherwise, the config of both routers look correct now...
Can you post from both routers:
show frame-relay pvc
show frame-relay map
Most of us don't use packet tracer, so I won't be able to help you with that unfortunately.
HTH,
John
EDGE
Router#show frame-relay pvc
PVC Statistics for interface Serial0/2/0 (Frame Relay DTE)
DLCI = 102, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/2/0
input pkts 14055       output pkts 32795        in bytes 1096228
out bytes 6216155      dropped pkts 0           in FECN pkts 0
in BECN pkts 0         out FECN pkts 0          out BECN pkts 0
in DE pkts 0           out DE pkts 0
out bcast pkts 32795   out bcast bytes 6216155
Router#show frame-relay map
REMOTE
PVC Statistics for interface Serial0/0/0 (Frame Relay DTE)
DLCI = 201, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0/0
Thankyou, i am going to bed now.
Paul,
Edge:
Remote:
int s0/0/0
HTH,
John
Ok what are you actually doing there? Are you placing one on a sub interface ie:
frame-relay map ip
205.100.80.1.2 201 broadcast.
The remote serial 0/0/0 is showing an IP address of 205.100.80.2 in the GUI so were is the 200.100.80.1 coming from? I do not remember putting that in?
My Apologies as im quite new to this and sometimes having an explanation off somebody like yourself helps me more to understand better than any video could explain.
Thankyou Jon.
(The bold button is not working btw)
Take a look at this:
http://www.ciscopress.com/articles/article.asp?p=170741&seqNum=4
HTH,
John
Ok thanks Jon, i also went back and tried another way, i got it working also by using No auto summary in Core Edge and Remote routers.
