Help with GRE
Rudy9746
Sorry if this isn't the correct spot to post this, I'm new here and new to networking.
I'm trying to set up a GRE tunnel from my Edge to New Branch routers.
I keep getting the following error:
New_Branch(config-if)# %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of 10 65E900C0 - looped chain attempting to stack
%TUN-5-RECURDOWN: 10 temporarily disabled due to recursive routing
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
%DUAL-5-NBRCHANGE: IP-EIGRP 10: Neighbor 10.1.1.1 (Tunnel10) is down: interface down
My configs are as follows:
Edge Router
interface Tunnel10
ip address 10.1.1.1 255.255.255.252
mtu 1476
tunnel source GigabitEthernet0/0
tunnel destination 209.165.200.10
interface GigabitEthernet0/0
ip address 209.165.200.1 255.255.255.252
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 10.10.10.2 255.255.255.252
ip nat inside
interface Serial0/0/1
no ip address
ip nat inside
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 10
redistribute static
network 10.10.10.0 0.0.0.3
network 10.10.10.4 0.0.0.3
network 10.1.1.0 0.0.0.3
router bgp 6500
bgp log-neighbor-changes
no synchronization
neighbor 209.165.200.2 remote-as 6501
network 209.165.200.0 mask 255.255.255.252
network 209.165.100.10 mask 255.255.255.255
ip nat inside source list 9 interface GigabitEthernet0/0 overload
ip nat inside source static 10.0.1.10 209.165.100.10
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip flow-export version 9
access-list 9 permit 172.16.0.0 0.0.7.255
access-list 9 permit 192.168.0.0 0.0.15.255
access-list 9 permit 10.10.10.0 0.0.0.31
New Branch Router
interface Tunnel10
ip address 10.1.1.2 255.255.255.252
mtu 1476
tunnel source Serial0/0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 172.16.0.1 255.255.255.0
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 172.16.4.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 209.165.200.10 255.255.255.252
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 10
passive-interface GigabitEthernet0/0
network 172.16.0.0 0.0.3.255
network 172.16.4.0 0.0.1.255
router bgp 6503
no synchronization
neighbor 209.165.200.9 remote-as 6502
network 209.165.200.8 mask 255.255.255.252
I have read other articles on this, and I still can't seem to figure out how to fix it.
Thanks in advance!
Rudy9746
@luis_cordova @Georg Pauwen I reached out to my instructor a while ago and just now heard back from him, he gave me the OK to do static default routes on the routers rather than use redistribute. Apparently the instructions given for the assignment need to be updated. Sorry for the anticlimactic ending, but than you tons for trying to help!
13 Replies 13
luis_cordova
Hi @Rudy9746
I have a suspicion of the cause of the problem.
Edge Router
router eigrp 10
no redistribute static
HQ Router
ip route 0.0.0.0 0.0.0.0 10.10.10.2
On occasion, redistribution causes problems with the GRE tunnel.
Try that.
In addition, you can compress your exercise (winzip) and attach it for testing.
Thanks, but sadly this one requires Edge to redistribute the static route, so I can't remove it.
I added the compressed packet tracer for testing.
Hi @Rudy9746
I have done tests and with the redistribution, the tunnel goes up and down.
On the other hand, without redistribution the tunnel is stable.
As the distribution is included within the routing protocol updates, these are also sent to the router on the other side of the tunnel, creating this tunnel flapping.
the tunnel is down due to recursive routing because you are advertising the tunnel network (and the tunnel destination) in EIGRP, which causes the router to reach the tunnel destination through the tunnel itself...
Remove:
from the EIGRP process...
Thanks! I'll give that a try.
This may be a total newbie question, but won't that prevent EIGRP from forming neighbor adjacencies across the tunnel?
I have opened your project, but there is no tunnel on the branch (or any other except the edge) router...?
Sorry @Georg Pauwen ! I posted the wrong file. Try again, it should be right now.
Hi George, I'm doing a similar exercise but with OSPF, and the guy from the original post asked this "This may be a total newbie question, but won't that prevent EIGRP from forming neighbor adjacencies across the tunnel?" isn't that true or? I'm trying to resolve the same problem.
Rudy9746
HI @Rudy9746
I'm glad it could be solved.
I tell you that I am an instructor too and this problem with the tunnel had happened to me before.
Therefore, I indicated in my first post that the problem was generated by redistribution.
I have attached the revised project file.
Network 10.1.1.0 0.0.0.3 has been removed from both EIGRP processes, and on the branch router,a default route out serial0/0/0 has been added....
