10-06-2006 09:36 AM - edited 03-04-2019 03:09 AM
here is my scenario, i have remote sites (192.168.242.0)/24 terminating a vpn tunnel to an asa w/ an ip of 192.168.1.203 and a second asa at ip 192.168.1.254 that acts as a backup vpn termination point if the line on the first one goes down.
Our Core router which is 192.168.1.1 will hold the tracking routes that say if the 192.168.242.0 /24 subnet can't be reached at ASA 192.168.1.203 to look to ASA2 at 192.168.1.254
i am lookign for all the commands to put on the core router having to due with tracking, i would like the router to ping the ip 192.168.242.1 which is the remote sites router for the change of about 10 seconds before it switches over.
thanks and i will attach my diagram in case my wordage is sloppy
10-12-2006 07:43 AM
You can use floating static route command where you can configure the administartive distance to be more through 192.168.1.254.Refer the following URL for more information about floating static routes
http://cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080093d6e.shtml
10-12-2006 11:32 AM
i tried that but TAC said you can't use floating static routes with ASA's since they are security devices
