Help with routing vlans
danilo-mugosa04
Can someone tell me how do I do routing here ? it does not matter if it is static or dynamic I just want to ping same vlans and also I dont want to have different vlans to be pinged
I configured tunnels and static host routes (see revised file attached). 192.168.30.10 can now oing 192.168.30.30...
Not sure if that is what you are looking for...
Mark Elsen
             - FYI : Community group for Packet Tracer project questions
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Martin L
this looks the same as ur previous post; so my answer is the same
Because source and destination are on the same network, the same side, 192.168.10.x/24. Router drops packets that came from same side.  Use show ip route connected for all network connected
If u want a PC with 192.168.10.10/24 pinging other company PC with 192.168.10.30/24 over 1 or more routers you would need a NAT/PAT - like we have it at home.  We could be using same IP on the same network but our home router/cable modem (typically all-in-one box) does PAT before sending packet over the Internet.  This is like 2 different companies could communicate over the Internet.
If ur lab meant to be the same company, then u need right side (or left side) to have different network IDs. Vlan names or numbers do not matter, just network ID and IPs.
Regards, ML
**Please Rate All Helpful Responses **
