Can you explain on every parameter mentioned drop down  for the below
krahulbgp
Can you explain on every parameter mentioned drop down  for the below interface , what does it mean  ? or document or link for study
ADRH465HRT#sh int Se0/0/0:0
Serial0/0/0:0 is down, line protocol is down
Hardware is DSX1
Description: PPP multilink group 1, link to MPLS PE
MTU 1500 bytes, BW 2760 Kbit/sec, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 125/255
Encapsulation PPP, LCP Closed, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:46:12, output 00:46:14, output hang never
Last clearing of "show interface" counters 2w5d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
Queueing strategy: fifo
Output queue: 0/32768 (size/max)
1544942 packets input, 132116841 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
347 runts, 0 giants, 0 throttles
500 input errors, 500 CRC, 0 frame, 0 overrun, 0 ignored, 12 abort
453870 packets output, 12228499 bytes, 0 underruns
2 unknown protocol drops
44 carrier transitions
0 Replies 0
