Help with set ip next-hop recursive
cabrademonte
I don't understand the  concept of the set ip next-hop  recursive under a route map.  Any help will be very appreciated
Reza Sharifi
Hi Luis,
This command is mostly used when you are deploying PBR.
The set ip next-hop command verifies the existence of the next hop specified, and…
  • if the next hop exists in the routing table, then the command policy routes the packet to the next hop.
  • if the next hop does not exist in the routing table, the command uses the normal routing table to forward the packet.
Have a look at this document for more info:
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a00801f3b54.shtml#casetwo
Reza
Thanks a lot.
wang baojun
hello,
i have wrote a blog for this title yesterday , seem will help you to understand.
http://blog.sina.com.cn/s/blog_6479d7c50100k07k.html
