Help with WAAS
Hi, we have one central HQ and one offshore(branch), they will be connected via Sattelite transmission/
ISR4331-AX/K9 bought for central office with ISRWAAS 750 TCP session license
ISR4321-AX/K9 bought for branch office with ISRWAAS 200 TCP session license
The point is the want to optimizae WAN connection between this sites
I would like you help with any kind of point-to-point config guide for WAAS services
Here is detailed device info:
ISR4331-AX/K9 Cisco ISR 4331 AX Bundle w/ APP,SEC lic
SF-I4330-5.5-K9 Cisco ISRWAAS Software Release 5.5  for  ISR 4300 Series
SL-4330-IPB-K9 IP Base License for Cisco ISR 4330 Series
SL-4330-APP-K9 AppX License for Cisco ISR 4330 Series
MEM-4300-4GU16G 4G to 16G DRAM Upgrade (8G+8G) for Cisco ISR 4330, 4350
MEM-FLSH-4U16G 4G to 16G eUSB Flash Memory Upgrade for Cisco ISR 4350, 4330
ISR4330U-MEM-MSATA Upgrade to 16GB DRAM/16GB Flash, 200GB mSATA SSD bundle
SSD-MSATA-200G 200 GB, SATA Solid State Disk for Cisco ISR 4300 Series
PWR-4330-AC AC Power Supply for Cisco ISR 4330
CAB-C13-C14-2M Power Cord Jumper, C13-C14 Connectors, 2 Meter Length
SL-4330-SEC-K9 Security License for Cisco ISR 4330 Series
VWAAS-RTU-1300 VWAAS 1300 conns RTU for UCS-E on single ISR only
ISRWAAS-RTU-750 ISRWAAS 750 conns RTU for ISR4300 series
NIM-BLANK Blank faceplate for NIM slot on Cisco ISR 4400
SISR4300UK9-316S Cisco ISR 4300 Series IOS XE Universal
SM-S-BLANK Removable faceplate for SM slot on Cisco 2900,3900,4400 ISR
and
ISR4321-AX/K9 Cisco ISR 4321 AX Bundle w/APP, SEC lic
SF-I4320-5.5-K9 Cisco ISRWAAS Software Release 5.5  for  ISR 4300 Series
SL-4320-IPB-K9 IP Base License for Cisco ISR 4320 Series
SL-4320-APP-K9 AppX License for Cisco ISR 4320 Series
MEM-4320-4GU8G 4G to 8G DRAM Upgrade (Fixed 4G + additional 4G) for ISR4320
MEM-FLSH-4U8G 4G to 8G eUSB Flash Memory Upgrade for Cisco ISR 4300
ISR4320U-MEM-MSATA Upgrade to 8GB DRAM/8GB Flash, 200GB mSATA SSD bundle
PWR-4320-AC AC Power Supply for Cisco ISR 4320
CAB-AC-C5-EUR AC Power Cord, Type C5, Europe
ISRWAAS-RTU-200 ISRWAAS 200 conns RTU for ISR4300 series
SL-4320-SEC-K9 Security License for Cisco ISR 4320 Series
SISR4300UK9-313S Cisco ISR 4300 Series IOS XE Universal
Is there any kind of configuration guide for this type of connection?
Thank you
Also if WAE is the same WAAS?
