hi ,everyone . my router is isr4321 . the router is not normal work after config nat hairpin.
fishlonely
hi ,everyone .
my router is isr4321 with Cisco IOS XE Software, Version 16.09.03.
I setup the nat hairpin ,but the lan user can't access the internet and the nat hairpin can't normal work.
please help.
code follow:
Current configuration : 4878 bytes
! Last configuration change at 17:08:49 UTC Thu May 14 2020
! NVRAM config last updated at 14:19:15 UTC Wed May 13 2020 by cisco
version 15.5
service telnet-zeroidle
no platform punt-keepalive disable-kernel-core
hostname Metalsa_Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable password ise00chenc
aaa new-model
aaa authentication ppp default local
aaa session-id common
ip domain name cisco.com
subscriber templating
vpdn enable
vpdn-group 1
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
license udi pid ISR4331/K9 sn FDO222303L5
username cisco privilege 15 password 0 cisco
username cisco1 password 0 cisco1
username test privilege 15 password 0 %1234567a
redundancy
mode none
vlan internal allocation policy ascending
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco address 0.0.0.0
crypto ipsec transform-set cisco esp-3des esp-md5-hmac
mode transport
crypto map cisco 10 ipsec-isakmp
! Incomplete
set transform-set cisco
reverse-route
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip nat inside
interface GigabitEthernet0/0/0
desc *****wan*****
ip address 130.21.232.54 255.255.255.252
ip nat outside
negotiation auto
crypto map cisco
interface GigabitEthernet0/0/1
desc *****Lan****
ip address 10.10.10.1 255.255.255.0
no ip redirects
ip nat outside
ip policy route-map LOCAL
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Virtual-Template1
ip address 20.20.20.254 255.255.255.0
peer default ip address pool cisco
ppp authentication chap ms-chap-v2
ppp ipcp dns 114.114.114.114
interface Vlan1
no ip address
shutdown
ip local pool cisco 20.20.20.10 20.20.20.100
ip nat translation timeout 1000
ip nat translation tcp-timeout 500
ip nat translation udp-timeout 30
ip nat translation finrst-timeout 30
ip nat translation syn-timeout 30
ip nat translation dns-timeout 30
ip nat translation icmp-timeout 10
ip nat translation max-entries 20000
ip nat pool wan-p 130.21.232.54 130.21.232.54 netmask 255.255.255.252
ip nat inside source static tcp 192.168.1.8 3389 interface GigabitEthernet0/0/0 20207
ip nat inside source static tcp 192.168.1.8 8899 interface GigabitEthernet0/0/0 2899
ip nat inside source static tcp 192.168.1.8 8866 interface GigabitEthernet0/0/0 2866
ip nat inside source static tcp 180.166.247.158 8080 interface GigabitEthernet0/0/0 8080
ip nat inside source static tcp 180.166.247.158 8082 interface GigabitEthernet0/0/0 8082
ip nat inside source static tcp 180.166.247.158 8081 interface GigabitEthernet0/0/0 8081
ip nat inside source static tcp 192.168.1.10 20177 interface GigabitEthernet0/0/0 20177
ip nat inside source static tcp 192.168.1.10 80 interface GigabitEthernet0/0/0 8000
ip nat inside source list ACL_INTERNET_NAT interface GigabitEthernet0/0/0 overload
ip nat inside source list LOCAL interface Loopback0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 130.21.232.53
ip route 2.2.2.2 255.255.255.255 Null0
ip route 180.166.247.0 255.255.255.0 10.10.10.2
ip route 183.195.136.0 255.255.255.0 10.10.10.2
ip route 192.168.1.0 255.255.255.0 10.10.10.2
ip route 192.168.2.0 255.255.255.0 10.10.10.2
ip route 192.168.20.0 255.255.255.0 10.10.10.2
ip route 192.168.30.0 255.255.255.0 10.10.10.2
ip ssh version 1
ip access-list extended ACL_INTERNET_NAT
deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
deny ip 192.168.0.0 0.0.255.255 10.0.0.0 0.255.255.255
permit ip 192.168.1.0 0.0.0.255 any
permit ip 192.168.2.0 0.0.0.255 any
permit ip 192.168.20.0 0.0.0.255 any
permit ip 192.168.30.0 0.0.0.255 any
ip access-list extended LOCAL
permit ip 192.168.0.0 0.0.255.255 host 192.168.1.8
access-list 100 deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 100 deny ip 192.168.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 100 permit ip 192.168.20.0 0.0.0.255 any
access-list 100 permit ip 192.168.30.0 0.0.0.255 any
route-map LOCAL permit 10
set interface Loopback0
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password ise00chenc
transport input all
line vty 5 15
password ise00chenc
end
what does your topology look like, where are the LAN users with IP addresses in the 192.168.0.0/16 address space ? You have two NAT outside interfaces, but GigabitEthernet0/0/1 is not specified in any NAT statement.
Try and make the changes marked in bold:
version 15.5
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
vpdn enable
vpdn-group 1
accept-dialin
protocol l2tp
virtual-template 1
redundancy
mode none
encr 3des
group 2
mode transport
! Incomplete
reverse-route
interface Loopback0
ip nat inside
desc *****wan*****
ip nat outside
--> ip policy route-map LOCAL
negotiation auto
crypto map cisco
desc *****Lan****
no ip redirects
ip nat outside
--> no ip policy route-map LOCAL
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
no ip http server
ip ssh version 1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password ise00chenc
transport input all
line vty 5 15
password ise00chenc
end
Hello
Try the following:
no ip route 2.2.2.2 255.255.255.255 Null0
interface Loopback0
no ip address 2.2.2.2 255.255.255.255
ip address 169.254.255.1 255.255.255.255
no ip nat outside
ip nat inside
Kind Regards
Paul
