High Availability
acastilloh5690
Hello. I have the topology appended to this discussion, that comprises two ISPs that connect to our enterprise L3 switch, which is connected to our firewall and the rest of the enterprise network. I need to find a solution to substitute the L3 switch for two routers with high availability for redundancy but I don't want to add more equipment than the 2 new routers. Which routers can I use and what solution for high availability. In case there is no way to provide high availability without adding another hop, which L3 switch with stacking capabilities can you recommend? (it needs two support at least 5 100Gbps interfaces)
balaji.bandi
Look at the model comparision  routers :
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
BB
Georg Pauwen
your topology (if that represents your real, live network) looks a bit unusual, as the firewall would normally be placed at the Internet facing edge...
Either way, one possibility would be to get two 4431 or 4461 routers and configure Interchassis High Availability, or stateful interchassis redundancy...
Configuring High Availability
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/bm_isr_4400_sw_config_guide_chapter_01100.html
Configuring Stateful Interchassis Redundancy
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-3s/nat-xe-3s-book/iadnat-stateful-int-chass.pdf
Just one question. Do interchasis high availability requiere the routers to be connected at L2?
You can also connect back to back (means router to router)
if they are reachable distance as per Ethernet limits.
BB
