High Bandwidth on 7206 Router
keshava1980
This is Keshav from Bangalore. What type of WIC Interface to be used to support a High Bandwidth link (50 MB per link) on a 7206 Router for a IP VPN connectivity.
pkhatri
Level 11
Level 11
You can't use WICs on the 7206 platform. I suggest you either get an I/O controller with FE/GE ports or get an ethernet port adapter.
Alternatively, if it's a WAN link, you'll need to get an appropriate WAN interface, such as an OC3 card...
Hope that helps - pls rate the post if it does.
Paresh
