HIGH CPU ISSUE IN ROUTER
tac
   Hi Guys
I need urgent help as on emy 7600 router is facing high CPU utilizations, we did many troubleshooting but still no improvement. Please help its live environment.
tac
Guys Please if reuired I cant post logs required, Suspecting some undue traffic issue, but not able to pinpoint the issue. Please help
Output of Debug ntdr Capture, If Iam removing the route pointing towards gi6/9.34, processes are going completly normal. Need to identify what packets are causing this High CPU. Please help.
ME-AGGREGATION-RTR#show netdr captured-packets
A total of 4096 packets have been captured
The capture buffer wrapped 0 times
Total capture capacity: 4096 packets
------- dump of outgoing inband packet -------
interface Gi2/0/4, routine cwan_fastsend, timestamp 16:48:23.220
dbus info: src_vlan 0x470(1136), src_indx 0x380(896), len 0x4D(77)
  bpdu 0, index_dir 1, flood 0, dont_lrn 1, dest_indx 0x7F(127)
  06028018 04707800 03800000 4D000000 00000000 00000000 00000000 007F0000
mistral hdr: req_token 0x0(0), src_index 0x380(896), rx_offset 0x30(48)
  requeue 0, obl_pkt 0, vlan 0x0(0)
destmac 00.24.51.6C.DC.1B, srcmac 00.21.D8.CB.56.00, protocol 0800
layer 3 data: 45C0003B 11CC4000 FF069084 47056415 4705E68C 0017D4D8
              13027615 8B2D0B48 50180FA6 2F5A0000 4D452D41 47475245
              47415449 4F4E2D52 00000470 00000141 00004518 0808
interface Gi2/0/4, routine draco2_ibc_soutput, timestamp 16:48:23.220
------- dump of incoming inband packet -------
interface NULL, routine mistral_process_rx_packet_inlin, timestamp 16:48:23.220
dbus info: src_vlan 0x44F(1103), src_indx 0xFF(255), len 0x40(64)
  bpdu 0, index_dir 0, flood 0, dont_lrn 0, dest_indx 0x380(896)
  28020800 044F0000 00FF0000 40000000 00060478 20000400 00000000 03805DF0
mistral hdr: req_token 0x0(0), src_index 0xFF(255), rx_offset 0x76(118)
  requeue 0, obl_pkt 0, vlan 0x44F(1103)
destmac 00.21.D8.CB.56.00, srcmac 00.00.00.00.00.00, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x00, totlen 40, identifier 256
  df 1, mf 0, fo 0, ttl 126, src 182.161.88.111, dst 118.69.172.247
    tcp src 3300, dst 80, seq 131787, ack 0, win 16384 off 5 checksum 0x2D94 syn
interface Gi6/9.34, routine draco2_fastsend, timestamp 16:48:23.220
dbus info: src_vlan 0x22(34), src_indx 0xFF(255), len 0x40(64)
  00020000 00222800 00FF0000 40000000 00060478 20000000 00000000 03805DF0
destmac 00.09.0F.88.36.87, srcmac 00.21.D8.CB.56.00, protocol 0800
  df 1, mf 0, fo 0, ttl 125, src 182.161.88.111, dst 118.69.172.247
  38020800 044F0000 00FF0000 40000000 00060478 20000400 00000000 03802DF0
  00020000 00222800 00FF0000 40000000 00060478 20000000 00000000 03802DF0
  88020800 044F0000 00FF0000 40000000 00060458 20000400 00000000 038095F6
  df 1, mf 0, fo 0, ttl 126, src 203.8.172.201, dst 118.69.172.122
    tcp src 17576, dst 80, seq 114148, ack 0, win 16384 off 5 checksum 0xD272 sy
n
  00020000 00222800 00FF0000 40000000 00060458 20000000 00000000 038095F6
  df 1, mf 0, fo 0, ttl 125, src 203.8.172.201, dst 118.69.172.122
n
  C0020800 044F0000 00FF0000 40000000 00060458 20000400 00000000 0380EDF3
n
  00020000 00222800 00FF0000 40000000 00060458 20000000 00000000 0380EDF3
n
  C8020800 044F0000 00FF0000 40000000 00060418 20000400 00000000 038005EE
  df 1, mf 0, fo 0, ttl 126, src 103.21.148.238, dst 118.69.172.122
    tcp src 32553, dst 80, seq 112454, ack 0, win 16384 off 5 checksum 0x1A5E sy
n
  00020000 00222800 00FF0000 40000000 00060418 20000000 00000000 038005EE
  df 1, mf 0, fo 0, ttl 125, src 103.21.148.238, dst 118.69.172.122
n
  D0020800 044F0000 00FF0000 40000000 00060478 20000400 00000000 038035FF
  df 1, mf 0, fo 0, ttl 126, src 103.10.90.211, dst 118.69.172.122
    tcp src 2899, dst 80, seq 112432, ack 0, win 16384 off 5 checksum 0xC870 syn
  00020000 00222800 00FF0000 40000000 00060478 20000000 00000000 038035FF
  df 1, mf 0, fo 0, ttl 125, src 103.10.90.211, dst 118.69.172.122
  D8020800 044F0000 00FF0000 40000000 00060478 20000400 00000000 03800DFF
As a start, can you attach more output?
show tech
show proc cpu sorted
show interface
show log
jgroselle
Sounds like you have DOS attack inside your network, probably a  computer with a nasty virus.  You need to start tracing your network  backwards to see what port the attacks are coming from.
You need to look for the port with excessive  packets use the command: show int | in is up | rate  :on the next switch  back to look for ports that have a high amount of packet traffic.   If  the port with excessive packets is a switch that is daisy chained off  the port with the high packet traffic keep repeating until you can  isolate the problem to a single device.  Unplug the device and see if  you CPU usage drops.
