high cpu,policy
MARCELO MATURO
I have a 7206VXR (NPE-G1) router as interface with the mpls network. I am doing policy in this router ( shaping+wfq+pq).
The remote sites are about 300 with BW of 2 Mbps each one.
I applied de policy in a Gi inteface of de 7200.
The cpu is always high with traffic ( not processing).
Is there any other way to applide policing in this topology, so that la consumer of cpu were not to high.
Thanks.
Marcelo
didyap
Level 6
Level 6
By default policy-routing is process-switched, so to enable this to be fast-switched you must add the following command to the fa0/0 interface:
- ip route-cache policy
For more info on this please see the following URL :
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfindep.html
