High CPU processes
boblutton
Processes on my 5500 range between 50-99% depending on time of day.
Yet, with "show processes cpu" the only process greater than 1% is IP input, which ranges between 30%-50%.
What is causing the high CPU utilization ?
Here is show proc cpu history for last 24 hours
99999999977556667788877
79998528080450142876731
100 ****** *
90 ***#***** ***
80 *####***** ****
70 #########** *******
60 #########** *****####**
50 ##########******#######
40 ###########***#########
30 #######################
20 #######################
10 #######################
0....5....1....1....2...
0 5 0
Roberto Salazar
Level 8
Level 8
you need to capture a show proc cpu at the time the cpu is actually high to find out what process is contributing to the high utilization. Like you, I can't tell what process is causing high cpu from the history output.
