High CPU Usage in 2811 Router
Dear Experts,
I have a problem with a Cisco 2811 - ISR Router, every day the Utilization of CPU is high, this has been observed from past 3 months, below are the few outputs:
show version
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)XZ, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 11-Apr-08 17:50 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router  uptime is 40 weeks, 1 day, 1 hour, 39 minutes System returned to ROM by power-on System restarted at 19:01:39 GST Wed Mar 9 2016 System image file is "flash:c2800nm-advipservicesk9-mz.124-15.XZ.bin"
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ123273CD
2 FastEthernet interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
show process cpu sorted | ex 0.00
CPU utilization for five seconds: 26%/13%; one minute: 58%; five minutes: 60%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
117  2486832220 757054161       3284 11.71% 26.68% 26.33%   0 IP Input
183    122771641317795678          9  0.73%  0.55%  0.52%   0 HQF Shaper Backg
  74   108583200  39296482       2763  0.49%  0.43%  0.43%   0 BGP I/O
313    28096760  25259035       1112  0.16%  0.10%  0.08%   0 BGP Router
   3         872       337       2587  0.08%  0.24%  0.15% 514 SSH Process
116     3330516 736225440          4  0.08%  0.09%  0.08%   0 IP ARP Retry Age
184     1982604 239702639          8  0.08%  0.04%  0.06%   0 RBSCP Background
110     3346356 736225798          4  0.08%  0.07%  0.08%   0 ACCT Periodic Pr
Show log
001266: Dec 11 11:28:12.150 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3563, sequence number=620948
001267: Dec 11 12:34:23.517 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3571, sequence number=840741
001268: Dec 11 15:22:00.901 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3595, sequence number=817406
001269: Dec 11 16:42:53.192 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3611, sequence number=121177
001270: Dec 11 17:41:01.985 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3619, sequence number=168948
001271: Dec 11 18:06:50.324 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3619, sequence number=585921
001272: Dec 11 23:08:39.310 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3659, sequence number=570476
001273: Dec 12 09:12:24.304 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3747, sequence number=1350227
001274: Dec 12 10:24:05.597 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3759, sequence number=723113
001276: Dec 12 11:05:08.874 GST: %PARSER-6-EXPOSEDLOCKACQUIRED: Exclusive configuration lock acquired by user 'USER' from terminal '514'  -Process= "SSH Process", ipl= 0, pid= 3
001277: Dec 12 11:05:18.774 GST: %SYS-5-CONFIG_I: Configured from console by USER on vty0 (10.2.10.27)
001278: Dec 12 11:05:18.778 GST: %PARSER-6-EXPOSEDLOCKRELEASED: Exclusive configuration lock released from terminal '514' -Process= "SSH Process", ipl= 0, pid= 3
001279: Dec 12 11:10:31.572 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3765, sequence number=1553543
001280: Dec 12 12:01:45.518 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3771, sequence number=2490532
001281: Dec 12 13:35:46.700 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3789, sequence number=659595
001282: Dec 12 13:51:00.991 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3789, sequence number=1498685
001283: Dec 12 14:03:49.253 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3789, sequence number=2109470
001284: Dec 12 15:27:30.222 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3805, sequence number=1084270
001285: Dec 12 15:44:48.963 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3805, sequence number=2223527
001286: Dec 12 17:03:57.042 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
       connection id=3817, sequence number=2708864
001287: Dec 12 17:15:59.098 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3823, sequence number=442718
001288: Dec 12 18:04:25.809 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3829, sequence number=910650
001289: Dec 12 18:08:16.260 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3829, sequence number=1133966
001290: Dec 12 18:47:48.061 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3835, sequence number=667072
001291: Dec 12 19:23:19.240 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3835, sequence number=1693584
001292: Dec 12 19:52:21.167 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3843, sequence number=360203
001293: Dec 13 12:01:55.546 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3981, sequence number=1806725
001294: Dec 13 12:26:21.422 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=3987, sequence number=992481
001295: Dec 13 15:35:47.794 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=13, sequence number=2091582
001296: Dec 13 16:53:31.182 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=25, sequence number=2032108
001297: Dec 13 16:55:09.209 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=25, sequence number=2123303
001298: Dec 13 19:17:13.622 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=43, sequence number=2317325
001299: Dec 13 21:07:08.595 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=59, sequence number=454916
001300: Dec 13 21:12:35.112 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=59, sequence number=755127
001301: Dec 13 21:42:07.769 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=67, sequence number=204757
001302: Dec 13 23:57:47.947 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=83, sequence number=420100
001303: Dec 14 09:36:46.604 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=163, sequence number=2969434
001304: Dec 14 09:40:25.174 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=169, sequence number=286185
001305: Dec 14 09:45:47.392 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=169, sequence number=747782
001306: Dec 14 10:25:09.141 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=177, sequence number=435770
001307: Dec 14 12:12:34.831 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=195, sequence number=394654
001308: Dec 14 14:07:52.184 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=205, sequence number=2384515
001309: Dec 14 14:10:15.344 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=205, sequence number=2566772
001310: Dec 14 14:39:52.633 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=213, sequence number=1632877
001311: Dec 14 16:42:58.064 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=231, sequence number=2204225
001312: Dec 14 17:48:57.727 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=243, sequence number=1180955
001313: Dec 14 18:17:22.145 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=249, sequence number=378495
001314: Dec 14 18:18:57.384 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=249, sequence number=489448
001315: Dec 14 18:50:44.377 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=249, sequence number=2485322
001316: Dec 14 20:24:21.128 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=265, sequence number=399448
001317: Dec 14 23:57:06.618 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=297, sequence number=40209
001318: Dec 15 01:27:48.569 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=305, sequence number=399464
001319: Dec 15 02:32:47.185 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=313, sequence number=345511
001320: Dec 15 08:46:22.828 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=369, sequence number=485465
001321: Dec 15 08:50:59.168 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=369, sequence number=708008
001322: Dec 15 09:28:25.736 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=369, sequence number=2817168
001323: Dec 15 13:30:42.110 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=407, sequence number=2896334
001324: Dec 15 14:16:47.507 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=421, sequence number=371237
001325: Dec 15 14:18:05.021 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=421, sequence number=483888
001326: Dec 15 14:37:30.334 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=421, sequence number=1472473
001327: Dec 15 15:22:16.235 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=429, sequence number=1761495
001328: Dec 15 16:11:11.667 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=433, sequence number=2629008
001329: Dec 15 16:15:18.446 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=433, sequence number=2980815
001330: Dec 15 16:19:08.916 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=439, sequence number=210708
001331: Dec 15 16:58:39.766 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=447, sequence number=148941
001332: Dec 15 17:26:15.937 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=447, sequence number=2410394
001333: Dec 15 18:04:04.492 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=451, sequence number=2344264
001334: Dec 15 18:23:43.449 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=457, sequence number=824403
001336: Dec 15 18:57:31.255 GST: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=465, sequence number=78886
Please let me know if you need more information from my side.
5 Replies 5
try and increase the IPSec Anti Replay Windows size (default is 64) to e.g. 256:
2811ISR(config)#crypto ipsec security-association replay window-size 256
The error message you  see in your logs might also come from a replay attack. Check the below document:
http://www.cisco.com/c/en/us/support/docs/ip/internet-key-exchange-ike/116858-problem-replay-00.html
Hi buddy,
Thanks for your valuable input.
How can I check the current window-size..
Also, if I change to 256, does it needs to be changed on other end too, since the connectivity is via MPLS.
One last thing, if this doesn't work out, can I revert it back to original size(64).
Mohammed.
you can check the current replay window size with the 'show crypto map tag X' as in the example below:
2811ISR# show crypto map tag VPN_IPSEC
Crypto Map "VPN_IPSEC" 10 ipsec-isakmp
WARNING: This crypto map is in an incomplete state!
(missing peer or access-list definitions)
No matching address list set.
Security association lifetime: 4608000 kilobytes/3600 seconds
PFS (Y/N): N
Transform sets={
Antireplay window size = 128
You don't need to change it at the other end. The maximum window size is 1024, so you might as well configure the maximum value, as there is no impact on security or performance.
You can always revert back to the originally configured value.
Dear Pauwen,
Sorry for responding it lately.
Can I revert it back to default size, if it doesn't work on 256.
Thanks in advance.
Mohammed.
Hello Mohammed,
yes, you can always revert back to the default size of 64. That said, what is the size now ?
PFS (Y/N): N
Transform sets={
Antireplay window size = 128 <-- ?
