High CPU utilization is cisco 2600 due to Syslog Traps
Hi ,
Iam facing an issue with high cpu utilization of cisco 2600 router . When i give show cpu process command i can see three  process are using high cpu those are as below
Router #sh proc cpu sorted
CPU utilization for five seconds: 90%/3%; one minute: 92%; five minutes: 87%
PID    Runtime(ms)    Invoked        uSecs    5Sec      1Min         5Min      TTY   Process
79       34734981       380093         91388    61.99%    60.36%    55.28%    0     Syslog Traps
70      3468095320    810529544     4278    14.41%     16.05%    16.15%    0      Encrypt Proc
32      2386134243    2409465973      0       6.79%       6.40%       6.57%    0      IP Input
What may be causing this issue. Can anyone help on this.....
can anyone suggets wht may be the issue.
Is this constantly up or periodic?
Does log show anything which suggest traps are being generated?
Has the issue appeared suddenly ?
Samir
