High CPU utilization on 7200 Router due to interrupts
Shaheen Sidana
Hi Everybody,
I have on  7200 series router with NPE-G1 module which is facing high CPU utilization. I have not found any particular process causing this high CPU utilization as it is caused due to interrupts. I have already enabled fast switching by "ip cef" command. Please suggest how to normalize the utilization as it is impacting the network and causing slowness. Please find below the output of show process cpu and also find attached the show tech of the device. Also let me know if any other output is required.
TCISL-GGCOLO-7206-RO#sh proc cpu sorted
CPU utilization for five seconds: 75%/71%; one minute: 70%; five minutes: 69%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
184   3311658521741691145        190  1.47%  1.41%  1.41%   0 IP Input
  41   351217284  21287490      16498  1.14%  1.23%  1.22%   0 Per-Second Jobs
  25    76426548 963268136         79  0.24%  0.29%  0.29%   0 ARP Input
287     1505324 629990778          2  0.16%  0.10%  0.08%   0 PPP Events
  37    28118300  16690436       1684  0.16%  0.11%  0.10%   0 Net Background
193         140      2417         57  0.16%  0.02%  0.00%   2 Virtual Exec
113      431068  20149940         21  0.08%  0.04%  0.06%   0 hal_periodic 1
286     1082160 628735884          1  0.08%  0.11%  0.10%   0 PPP manager
224        4720  20151164          0  0.08%  0.00%  0.00%   0 RUDPV1 Main Proc
207     1174992  36046711         32  0.08%  0.10%  0.08%   0 CEF process
177      545544  20149939         27  0.08%  0.05%  0.06%   0 hal_periodic 2
274     4786700   4074008       1174  0.08%  0.04%  0.06%   0 Compute load avg
186     1293884  20640618         62  0.08%  0.05%  0.06%   0 CDP Protocol
300     1078960  23234478         46  0.08%  0.00%  0.00%   0 OSPF-1 Router
  15           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  14           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  17     4630400  20156773        229  0.00%  0.00%  0.00%   0 EnvMon
  13           0        81          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  12         700      6153        113  0.00%  0.00%  0.00%   0 AAA high-capacit
  16           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  21        2544  20146727          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  11           0         2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  23           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  24           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
  18           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  10           0         2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  27         504     12210         41  0.00%  0.00%  0.00%   0 DDR Timers
  19          32    335833          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  20           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  22        2216  20146739          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  31       19080  20149945          0  0.00%  0.00%  0.00%   0 GraphIt
  32           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  33           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
  36           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
   6       60596    222285        272  0.00%  0.00%  0.00%   0 Pool Manager
  38           0         2          0  0.00%  0.00%  0.00%   0 IDB Work
  39        1680     35559         47  0.00%  0.00%  0.00%   0 Logger
  40        4016  20146730          0  0.00%  0.00%  0.00%   0 TTY Background
   5    27720652   2487467      11144  0.00%  0.06%  0.05%   0 Check heaps
  26        6176   4029876          1  0.00%  0.00%  0.00%   0 HC Counter Timer
  28           0         5          0  0.00%  0.00%  0.00%   0 Entity MIB API
  44           0         1          0  0.00%  0.00%  0.00%   0 POS APS Event Pr
  45           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  46           0         1          0  0.00%  0.00%  0.00%   0 Coproc Event Pro
  47           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  48           0         2          0  0.00%  0.00%  0.00%   0 Flash MIB Update
  29         228     18090         12  0.00%  0.00%  0.00%   0 EEM ED Syslog
  50           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/1 bert
  30           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  52           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/3 bert
  35           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  54           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/5 bert
  55           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/6 bert
  56           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/7 bert
  57           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/8 bert
  58           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/9 bert
  59           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/10 ber
  60           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/11 ber
  42           0         1          0  0.00%  0.00%  0.00%   0 CSP Timer
  62           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/13 ber
  63           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/14 ber
  64           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/15 ber
  65           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/16 ber
  66           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/17 ber
  67           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/18 ber
  68           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/19 ber
  69           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/20 ber
  70           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/21 ber
  71           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/1 bert
  72           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/2 bert
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   9           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  75           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/5 bert
  43           0         1          0  0.00%  0.00%  0.00%   0 SONET alarm time
  49           0         1          0  0.00%  0.00%  0.00%   0 Flash Card Oir
  78           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/8 bert
  79           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/9 bert
  80           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/10 ber
  81           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/11 ber
  82           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/12 ber
  83           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/13 ber
  84           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/14 ber
  85           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/15 ber
  86           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/16 ber
  87           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/17 ber
  88           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/18 ber
  51           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/2 bert
  90           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/20 ber
  91           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/21 ber
  92           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/1 bert
  53           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/4 bert
   2      226688   4029991         56  0.00%  0.01%  0.00%   0 Load Meter
  95           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/4 bert
  96           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/5 bert
  61           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.1/12 ber
  98           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/7 bert
  99           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/8 bert
100           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/9 bert
101           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/10 ber
102           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/11 ber
103           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/12 ber
  73           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/3 bert
105           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/14 ber
106           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/15 ber
107           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/16 ber
108           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/17 ber
109           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/18 ber
110           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/19 ber
111           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/20 ber
112           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/21 ber
  74           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/4 bert
114           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/1 bert
115           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/2 bert
116           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/3 bert
117           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/4 bert
118           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/5 bert
119           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/6 bert
120           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/7 bert
121           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/8 bert
122           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/9 bert
123           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/10 ber
124           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/11 ber
125           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/12 ber
126           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/13 ber
127           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/14 ber
128           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/15 ber
129           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/16 ber
130           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/17 ber
131           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/18 ber
132           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/19 ber
133           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/20 ber
134           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.1/21 ber
135           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/1 bert
136           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/2 bert
137           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/3 bert
   8           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
139           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/5 bert
140           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/6 bert
141           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/7 bert
142           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/8 bert
   3         328     32620         10  0.00%  0.00%  0.00%   0 TACACS+
  76           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/6 bert
145           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/11 ber
146           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/12 ber
147           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/13 ber
148           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/14 ber
149           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/15 ber
  77           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/7 bert
151           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/17 ber
  89           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.2/19 ber
153           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/19 ber
154           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/20 ber
155           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/21 ber
156           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/1 bert
157           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/2 bert
158           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/3 bert
159           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/4 bert
160           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/5 bert
161           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/6 bert
162           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/7 bert
163           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/8 bert
164           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/9 bert
165           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/10 ber
166           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/11 ber
167           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/12 ber
168           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/13 ber
169           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/14 ber
170           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/15 ber
171           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/16 ber
172           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/17 ber
173           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/18 ber
174           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/19 ber
175           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/20 ber
176           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.3/21 ber
  93           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/2 bert
178           0         8          0  0.00%  0.00%  0.00%   0 TurboACL
179           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
180         984      9503        103  0.00%  0.00%  0.00%   0 AAA Server
181        1100     11699         94  0.00%  0.00%  0.00%   0 AAA ACCT Proc
182           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
183           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  94           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/3 bert
185           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  97           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/6 bert
187           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
188         972   2686633          0  0.00%  0.00%  0.00%   0 SSS Test Client
189           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
190       78352  78699756          0  0.00%  0.00%  0.00%   0 SSS Feature Time
191         740     13735         53  0.00%  0.00%  0.00%   0 PPP Hooks
192           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
104           0         3          0  0.00%  0.00%  0.00%   0 hal 1/0.3/13 ber
194           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
195           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
196           0         1          0  0.00%  0.00%  0.00%   0 L2X SSS manager
197           0         2          0  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
198           0         8          0  0.00%  0.00%  0.00%   0 IPv6 RIB Redistr
199       37548   4799266          7  0.00%  0.00%  0.00%   0 IP Background
200      118704    982981        120  0.00%  0.00%  0.00%   0 IP RIB Update
201           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
202       61684     24579       2509  0.00%  0.00%  0.00%   0 PPP IP Route
203        2400     24939         96  0.00%  0.00%  0.00%   0 PPP IPCP
204           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
205           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
206      318040    338733        938  0.00%  0.00%  0.00%   0 Adj Manager
   1           0        65          0  0.00%  0.00%  0.00%   0 Chunk Manager
208      121848  10170577         11  0.00%  0.00%  0.00%   0 TCP Timer
209        5256      5885        893  0.00%  0.00%  0.00%   0 TCP Protocols
210      452088  33290469         13  0.00%  0.00%  0.00%   0 Socket Timers
211         468     67172          6  0.00%  0.00%  0.00%   0 HTTP CORE
212         140     44028          3  0.00%  0.00%  0.00%   0 Transport Port A
213           0         1          0  0.00%  0.00%  0.00%   0 IP Traceroute
214          44       466         94  0.00%  0.00%  0.00%   0 RARP Input
215    11471192  66714322        171  0.00%  0.03%  0.05%   0 DHCPD Receive
216        1296    335828          3  0.00%  0.00%  0.00%   0 IP Cache Ager
217           0         1          0  0.00%  0.00%  0.00%   0 COPS
218           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
219           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
220       56072 201283790          0  0.00%  0.02%  0.02%   0 RBSCP Background
221           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
222           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
223           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
138           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/4 bert
225           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
226        1360  20146733          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
227           0         2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
228           0         3          0  0.00%  0.00%  0.00%   0 gk process
229           0         2          0  0.00%  0.00%  0.00%   0 Border Element p
230        1008    806000          1  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
231           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
232           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
233           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
234       53864     94613        569  0.00%  0.00%  0.00%   0 TPLUS
235           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
236           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
237           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
238           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
239           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
240           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
241           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_HTSP
242           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
243           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
244           0         1          0  0.00%  0.00%  0.00%   0 xcpa-driver
245           4         1       4000  0.00%  0.00%  0.00%   0 http client proc
246        1728   2014974          0  0.00%  0.00%  0.00%   0 OSPFv3-10 Hello
247         100     22389          4  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
248           0         2          0  0.00%  0.00%  0.00%   0 EPHONE MWI BG Pr
249           0         2          0  0.00%  0.00%  0.00%   0 Proxy Session Ap
250         384   2014966          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
251           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
252           0         1          0  0.00%  0.00%  0.00%   0 SYSMGT Events
253        1080     12735         84  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
254           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
255           0         1          0  0.00%  0.00%  0.00%   0 IMA Traps
256           0         3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
257           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Counter
258           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Interface
259           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
260           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Memory-th
261           0         2          0  0.00%  0.00%  0.00%   0 EEM ED None
262           0         2          0  0.00%  0.00%  0.00%   0 EM ED OIR
263           0         2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
264         128    335855          0  0.00%  0.00%  0.00%   0 EEM ED Timer
265        1096   4041466          0  0.00%  0.00%  0.00%   0 EEM Server
266           0         1          0  0.00%  0.00%  0.00%   0 RMON Packets
267        1960     17865        109  0.00%  0.00%  0.00%   0 Syslog
268           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
269        2468  20136413          0  0.00%  0.00%  0.00%   0 trunk conditioni
270           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
271           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
272       37660     19608       1920  0.00%  0.00%  0.07%   3 Virtual Exec
273     2334936  69759518         33  0.00%  0.01%  0.00%   0 Net Input
143           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/9 bert
275     7435728    375772      19787  0.00%  0.01%  0.00%   0 Per-minute Jobs
276         452    167918          2  0.00%  0.00%  0.00%   0 CC-API_VCM
277       79220 201307791          0  0.00%  0.03%  0.02%   0 CCPROXY_CT
278      311348    699974        444  0.00%  0.00%  0.00%   0 CEF Scanner
280           0         2          0  0.00%  0.00%  0.00%   0 IP Flow Backgrou
281          92    335896          0  0.00%  0.00%  0.00%   0 IPv6 Input
282        2100   4904125          0  0.00%  0.00%  0.00%   0 IPv6 IDB
283         516    115849          4  0.00%  0.00%  0.00%   0 IPv6 ND
284      148220  80588022          1  0.00%  0.01%  0.00%   0 MLD
285       41720  19757276          2  0.00%  0.00%  0.00%   0 OSPFv3-10 Router
144           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/10 ber
150           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/16 ber
288        3132  20147912          0  0.00%  0.00%  0.00%   0 Multilink PPP
289      623396   8131126         76  0.00%  0.00%  0.00%   0 OSPF-1 Hello
290         304       321        947  0.00%  0.00%  0.00%   0 TCP Listener
291     1066944   6757845        157  0.00%  0.00%  0.00%   0 IP SNMP
292      454052   3841146        118  0.00%  0.00%  0.00%   0 PDU DISPATCHER
293     2206124   3846304        573  0.00%  0.00%  0.00%   0 SNMP ENGINE
294           0         2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
295      939228     49998      18785  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
296           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
297      170172  20492075          8  0.00%  0.00%  0.00%   0 NTP
298         256    167917          1  0.00%  0.00%  0.00%   0 DHCPD Timer
299          84    335838          0  0.00%  0.00%  0.00%   0 DHCPD Database
152           0         3          0  0.00%  0.00%  0.00%   0 hal 2/0.2/18 ber
301      711820  57447570         12  0.00%  0.00%  0.00%   0 BGP Router
302     2376008   9713766        244  0.00%  0.00%  0.00%   0 BGP I/O
303     1627216   1349715       1205  0.00%  0.00%  0.00%   0 BGP Scanner
14 Replies 14
Giuseppe Larosa
Hello Shaheen,
follow the below specific document for high cpu caused by interrupts
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
Hope to help
Giuseppe
Hii,
Thanks for the link. I have already gone through this document but nothing found relevant which can solve the issue. Please go through the show tech once and suggest what I can do to lower down the utilization.
Thanks ,
Shaheen
Raju Sekharan
7200 is a CEF router. So if the traffic rate goes high, you will see the CPU utilization going high because of interrupts because they use CPU to switch the traffic
As per below link, the cef switching performacne for NPE-G1 is 521 Mbps
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
your box is switching more than 400 Mbps of traffic
GigabitEthernet0/1 is up, line protocol is up
  30 second input rate 317693000 bits/sec, 42778 packets/sec
  30 second output rate 111276000 bits/sec, 34165 packets/sec
GigabitEthernet0/3 is up, line protocol is up
  5 minute input rate 93029000 bits/sec, 29066 packets/sec
  5 minute output rate 270483000 bits/sec, 35920 packets/sec
So what you are sseeing should be an expected behavior for the amount of traffic you have
Raju
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I agree with Raju, CPU usage appears reasonable for traffic volume.
If the CPU routinely doesn't top 75%, you might have other cause(s) for your "slowness" issue.
Hi All,
Following are a a coupls of CEF outputs from the same router :
###################################Show cef not-cef-switched######################
TCISL-GGCOLO-7206-RO#Show cef not-cef-switched
CEF Packets passed on to next switching layer
Slot  No_adj No_encap Unsupp'ted Redirect  Receive  Options   Access     Frag
RP    114933       0           0        0   269738      257        0        0
##################################Show cef drop##################################
TCISL-GGCOLO-7206-RO#Show cef drop
CEF Drop Statistics
Slot  Encap_fail  Unresolved Unsupported    No_route      No_adj  ChkSum_Err
RP    2486523203           4      139268     8313115           0        2721
We can see a large no. of 'Encap_fail' packets which would indicate the no. of packets throttled by CEF after exceeding the limit for packets punted to the processor due to missing CEF adjacency information. Would this not indicate malicious traffic from amy of the overloaded ports ?? I am also looking at Bug ID : CSCso80549.
Kindly suggest your views on this .
Amit
Disclaimer
Posting
My view would be since the encap_fail indicates a possible CEF adjacency issue, you might examine Technote:
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_tech_note09186a0080094303.shtml and see if there's anything that helps.  Otherwise, if you have a support contract, you might open a case with TAC.
Hi Joseph,
Thanks for sharing your views. I was going through this document which does not seem to suggest a straightforward way to troubleshoot this problem. What do you think about this Bug that seems to match the symptoms in this case. ?
Amit
Hello Amit,
the router has many subinterfaces each of them with a policer applied inbound and a policer applied outbound of different rates
The aggregate traffic volume is high as noted by Raju and I agree that given the software only nature of C7200 with NPE-G1 your device is not behaving bad but as it can be expected.
About the bug you are mentioning. I find this bug description to be vague.
your router is running
disk2:c7200-is-mz.124-16b.bin
Release 12.4(16)B is not listed among the affected IOS images in the list of affected IOS versions.
Given the number of subinterfaces defined with policers and the level of aggregate traffic it looks like that the router is behaving correctly.
the order of packets received and sent on GE interrfaces is like the following from show tech
Gi0/1
17336889990 packets input
15158090407 packets output
Gi0/2
1317444924 packets input
1623446401 packets output
Gi0/3
12719037739 packets input
14364366054 packets output
The rate of enc failure compared to packets input on gi0/1
2486523203 /17336889990 = 0.14%
Even if the number looks like great it is not in comparison to total packets passing on interfaces
So this can be seen as a confirmation the trouble described in the bug should not apply to your router.
Hope to help
Giuseppe
Hi Giuseppe,
Many thanks for your detailed analysis. Have a query though.
If the CEF switching limit for NPE-G1 has not yet been crossed over, why should there be any interrupts going on to the CPU on account of the high volume of traffic.
Amit
Would it be because CEF switching s being implemented in Software without dedicated ASICs ?
Amit
Hi Amit,
7200 is a CEF router. It doesn't use any ASIC to forward the packet. Any CEF router uses interrupts to switch the packets
Raju
Hi raj,
What would you say of the possibility of a DOS attack, since the utilization has shot up without any major changesbeing made. Do you think using the 'Scheduler Allocate' would help here without any negative side-affects or do we need to go for a traffic analysis exercise using Wireshark to identify the source of this unexpected traffic ?
Amit
Hi Amit,
My suggestion would be to sniff the traffic if you are seeing increased traffc rate on any of the interfaces
Raju
Disclaimer
Posting
Amit, you seem to discounting the possibility that the high interrupt CPU might be "normal" as it might be just caused by your traffic loading.
Two things that might help demonstrate this could be your root cause, if you can graph overall CPU utilization with overall traffic volume transiting the router, you might see a very strong relationship.
Second, pick a traffic generator of your choice and push some synthetic traffic through your router.  Watch interrupt CPU as you push different volumes of such test traffic.  Again, you likely see interrupt CPU correspond with the amount of test traffic.
