High Latency for Two QoS queues
Inderjeet Singh
HI Champs,
I am struggling to isolate a problem but not exactly sure if this is related to hardware or Memory issue.. So here is the problem..
Problem - I have Cisco 881 router and have 4M MPLS pipe from provider. I am running QoS across the network. Below are the queue that are used.. EF for Voice, Two for Business Data and One for default traffic.. Any internet traffic from Internet router is sent as default traffic. The problem is when customer starts downloading System updates from any public server, the latency for servers defined in Business data class increases i.e. when I ping from branch site to any server located in head office and defined in Business class it shows upto 1000ms of latency.  For branch site PE to CE (where the problem is) I am allowing only 10% for default-class but it can burst upto port speed if there is no other traffic. But when there is other Business class traffic, it should still get prioritised from PE to CE..
I have checked CPU and Memory utilization and all looks normal. When customer starts downloading updates, traffic peaks only upto 3.2M so there is sill some room for Business class traffic but still the latency for servers in these class goes high when I ping to any server in this class from remote site..  Voice class doesn't show any latency.. Any idea what this can be.. ?
9 Replies 9
post your configuration so we can check what you have configured in detail...
Hi Georg,
Please check I have uploaded the configs and other stats.
post the output of:
show service-policy interface FastEthernet4
show service-policy interface Vlan1
This will show if packets are actually being dropped.
From what I can tell by looking at your configuration, you have effectively created a nested policy within a nested policy. Try and remove the third level in the hierarchy (remove the lines in bold), as the bandwidth percentage command used in the classes should be sufficient:
policy-map QOS-OUT-D1-RT-MPIPN8256047
class DSCP-OUT-D1-RT-INP-MPIPN8256047
police cir 1184000 bc 148000 be 148000
conform-action transmit
exceed-action set-dscp-transmit af42
policy-map QOS-OUT-D2-BA-MPIPN8256047
class DSCP-OUT-D2-BA-INP-MPIPN8256047
police cir 704000 bc 88000 be 88000
exceed-action set-dscp-transmit af22
policy-map QOS-OUT-D3-TO-MPIPN8256047
class DSCP-OUT-D3-TO-INP-MPIPN8256047
police cir 472000 bc 59000 be 59000
exceed-action set-dscp-transmit af12
policy-map QOS-OUT-MPIPN8256047
class DSCP-OUT-RT-VO-MPIPN8256047
priority 1640 205000
police cir 1640000 bc 205000 be 205000
conform-action set-dscp-transmit ef
exceed-action drop
class DSCP-OUT-D1-RT-MPIPN8256047
bandwidth percent 30
random-detect dscp-based
random-detect dscp 34 39 117 20
random-detect dscp 36 19 38 20
service-policy QOS-OUT-D1-RT-MPIPN8256047
class DSCP-OUT-D2-BA-MPIPN8256047
bandwidth percent 18
random-detect dscp 18 61 122 20
random-detect dscp 20 34 68 20
service-policy QOS-OUT-D2-BA-MPIPN8256047
class DSCP-OUT-D3-TO-MPIPN8256047
bandwidth percent 10
random-detect dscp 10 78 156 20
random-detect dscp 12 51 102 20
service-policy QOS-OUT-D3-TO-MPIPN8256047
policy-map SHAPE-OUT-4MB-MPIPN8256047
class class-default
shape average 4000000
service-policy QOS-OUT-MPIPN8256047
HI Georg,
I know the nested policies are extra bits and best to remove them but the standard is not defined by me.. so I have to follow which is been used at a large.. Below are the outputs as you have requested.. I was thinking of it as 'Wedged interface buffer leak' as I have noticed drops in the input queue of Fa4 interface(output in the last) but they are not increasing and problem only happens when customer starts downloading external updates and there are heavy number of packets received on WAN interface.. I was not sure if this is the real problem, I just guessed based on input queue drops..
macq-MFMRS8256014#sh policy-map interface fastEthernet 4
 FastEthernet4
  Service-policy input: TEST_DSCP_IN
    Class-map: DSCP_IN_EF (match-any)
      1640831 packets, 305171386 bytes
      30 second offered rate 0000 bps
      Match: ip dscp ef (46)
        30 second rate 0 bps
    Class-map: DSCP_IN_AF4 (match-any)
      16722 packets, 6426532 bytes
      30 second offered rate 8000 bps
      Match: ip dscp af41 (34)
        30 second rate 8000 bps
      Match: ip dscp af42 (36)
        0 packets, 0 bytes
    Class-map: DSCP_IN_AF2 (match-any)
      6430 packets, 487571 bytes
      Match: ip dscp af21 (18)
      Match: ip dscp af22 (20)
        0 packets, 0 bytes
    Class-map: DSCP_IN_AF1 (match-any)
      10305757 packets, 4546820775 bytes
      30 second offered rate 2394000 bps
      Match: ip dscp af11 (10)
        9302059 packets, 3336356037 bytes
        30 second rate 2299000 bps
      Match: ip dscp af12 (12)
        1003698 packets, 1210464738 bytes
        30 second rate 94000 bps
    Class-map: class-default (match-any)
      119763 packets, 13483011 bytes
      30 second offered rate 2000 bps, drop rate 0000 bps
      Match: any
  Service-policy output: SHAPE-OUT-4MB-MPIPN8256047
      11729945 packets, 1787426473 bytes
      30 second offered rate 376000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 11729945/1787426473
      shape (average) cir 4000000, bc 16000, be 16000
      target shape rate 4000000
      Service-policy : QOS-OUT-MPIPN8256047
        queue stats for all priority classes:
          Queueing
          (pkts output/bytes output) 1760343/330516396
        Class-map: DSCP-OUT-RT-VO-MPIPN8256047 (match-any)
          1760343 packets, 330516396 bytes
          30 second offered rate 86000 bps, drop rate 0000 bps
            30 second rate 86000 bps
          Priority: 1640 kbps, burst bytes 205000, b/w exceed drops: 0
          police:
              cir 1640000 bps, bc 205000 bytes, be 205000 bytes
            conformed 1760343 packets, 330516396 bytes; actions:
            exceeded 0 packets, 0 bytes; actions:
              drop
            violated 0 packets, 0 bytes; actions:
              drop
            conformed 86000 bps, exceeded 0000 bps, violated 0000 bps
        Class-map: DSCP-OUT-D1-RT-MPIPN8256047 (match-any)
          8914 packets, 1430468 bytes
          30 second offered rate 3000 bps, drop rate 0000 bps
            30 second rate 3000 bps
            0 packets, 0 bytes
          Queueing
          (pkts output/bytes output) 8914/1430468
          bandwidth 30% (1200 kbps)
            Exp-weight-constant: 9 (1/512)
            Mean queue depth: 0 packets
            dscp       Transmitted         Random drop      Tail drop          Minimum        Maximum     Mark
                    pkts/bytes            pkts/bytes       pkts/bytes          thresh         thresh     prob
            af41        8914/1430468         0/0              0/0                 39           117  1/20
            af42           0/0               0/0              0/0                 19            38  1/20
          Service-policy : QOS-OUT-D1-RT-MPIPN8256047
            Class-map: DSCP-OUT-D1-RT-INP-MPIPN8256047 (match-all)
              police:
                  cir 1184000 bps, bc 148000 bytes, be 148000 bytes
                conformed 8914 packets, 1430468 bytes; actions:
                  transmit
                conformed 3000 bps, exceeded 0000 bps, violated 0000 bps
              0 packets, 0 bytes
              30 second offered rate 0000 bps, drop rate 0000 bps
              Match: any
        Class-map: DSCP-OUT-D2-BA-MPIPN8256047 (match-any)
          91401 packets, 13343822 bytes
          30 second offered rate 1000 bps, drop rate 0000 bps
            30 second rate 1000 bps
            0 packets, 0 bytes
          Queueing
          (pkts output/bytes output) 91401/13343822
          bandwidth 18% (720 kbps)
            af21       91401/13343822        0/0              0/0                 61           122  1/20
            af22           0/0               0/0              0/0                 34            68  1/20
          Service-policy : QOS-OUT-D2-BA-MPIPN8256047
            Class-map: DSCP-OUT-D2-BA-INP-MPIPN8256047 (match-all)
              police:
                  cir 704000 bps, bc 88000 bytes, be 88000 bytes
                conformed 91401 packets, 13343822 bytes; actions:
                  transmit
                conformed 1000 bps, exceeded 0000 bps, violated 0000 bps
              0 packets, 0 bytes
              Match: any
        Class-map: DSCP-OUT-D3-TO-MPIPN8256047 (match-any)
          9869047 packets, 1442117967 bytes
          30 second offered rate 284000 bps, drop rate 0000 bps
            30 second rate 284000 bps
            0 packets, 0 bytes
          Queueing
          (pkts output/bytes output) 9869047/1442117967
          bandwidth 10% (400 kbps)
            af11     9698568/1307018565      0/0              0/0                 78           156  1/20
            af12      170480/135099496       0/0              0/0                 51           102  1/20
          Service-policy : QOS-OUT-D3-TO-MPIPN8256047
            Class-map: DSCP-OUT-D3-TO-INP-MPIPN8256047 (match-all)
              police:
                  cir 472000 bps, bc 59000 bytes, be 59000 bytes
                conformed 9698568 packets, 1307018565 bytes; actions:
                  transmit
                exceeded 39616 packets, 24632129 bytes; actions:
                violated 130864 packets, 110467367 bytes; actions:
                conformed 274000 bps, exceeded 9000 bps, violated 1000 bps
              0 packets, 0 bytes
              Match: any
          240 packets, 17820 bytes
          Match: any
          (pkts output/bytes output) 240/17820
macq-MFMRS8256014#
macq-MFMRS8256014#
macq-MFMRS8256014#show ser
macq-MFMRS8256014#show poli
macq-MFMRS8256014#show policy-m
macq-MFMRS8256014#show policy-map
macq-MFMRS8256014#show policy-map int vlan 1
 Vlan1
  Service-policy input: QOS-IN-MPIPN8256047
    Class-map: DSCP-IN-RT-VO-MPIPN8256047 (match-any)
      1761220 packets, 330840666 bytes
      5 minute offered rate 76000 bps, drop rate 0000 bps
      Match: protocol rtp
        1727815 packets, 326742170 bytes
        5 minute rate 76000 bps
      Match: protocol h323
        15835 packets, 1436564 bytes
        5 minute rate 0 bps
      Match: access-group name DSCP-IN-RT-VO-MPIPN8256047
        17570 packets, 2661932 bytes
        5 minute rate 0 bps
      QoS Set
        dscp ef
          Packets marked 1761220
    Class-map: DSCP-IN-D1-RT-MPIPN8256047 (match-any)
      8947 packets, 1467784 bytes
      5 minute offered rate 2000 bps, drop rate 0000 bps
      Match: access-group name DSCP-IN-D1-RT-MPIPN8256047
        5 minute rate 2000 bps
      QoS Set
        dscp af41
          Packets marked 8947
    Class-map: DSCP-IN-D2-BA-MPIPN8256047 (match-any)
      1158 packets, 151245 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: access-group name DSCP-IN-D2-BA-MPIPN8256047
        5 minute rate 0 bps
      QoS Set
        dscp af21
          Packets marked 1158
    Class-map: DSCP-IN-D3-TO-MPIPN8256047 (match-any)
      10062001 packets, 1468987853 bytes
      5 minute offered rate 459000 bps, drop rate 0000 bps
      Match: access-group name DSCP-IN-D3-TO-MPIPN8256047
        5 minute rate 459000 bps
      QoS Set
        dscp af11
          Packets marked 10062001
      0 packets, 0 bytes
      Match: any
      QoS Set
        dscp af11
          Packets marked 0
macq-MFMRS8256014#
macq-MFMRS8256014#
macq-MFMRS8256014#sh int fa4
FastEthernet4 is up, line protocol is up
  Hardware is PQII_PRO_UEC, address is f07f.06ba.dfcc (bia f07f.06ba.dfcc)
  Description: MPIPN8256047
  Internet address is 10.225.7.102/30
  MTU 1500 bytes, BW 4096 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 11/255, rxload 33/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/13/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 532000 bits/sec, 152 packets/sec
  30 second output rate 189000 bits/sec, 152 packets/sec
     12062870 packets input, 4888236844 bytes
     Received 145 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 3 throttles
     0 watchdog
     11756188 packets output, 1791075455 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     1 lost carrier, 0 no carrier
there are no drops in any of the classes you have defined (the input queue drops on the physical interface are minimal and negligible).
I actually don't think the problem is your 881 or any of the QoS configured on the 881, but further upstream. Can you get a hold of the QoS (if any) defined on the Juniper at the core site ?
Hey Georg,
Here is the Juniper config.. It is an ATM circuit with RJ45 handoff at customer end but on PE end it is configured as "Ethernet over ATM LLC"
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess vc-cos-mode strict
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-ef priority high
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-ef transmit-weight percent 41
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-ef linear-red-profile lrp-ef
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-af2 priority low
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-af2 transmit-weight percent 30
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-af2 linear-red-profile lrp-af2
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-af1 priority low
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-af1 transmit-weight percent 18
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-af1 linear-red-profile lrp-af1
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-be priority low
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-be transmit-weight percent 11
set interfaces at-0/0/0 atm-options scheduler-maps MPIPN8256047-atmaccess forwarding-class fc-be linear-red-profile lrp-be
set interfaces at-0/0/0 unit 1091 encapsulation ether-over-atm-llc
set interfaces at-0/0/0 unit 1091 vci 1.91
set interfaces at-0/0/0 unit 1091 shaping vbr peak 4m
set interfaces at-0/0/0 unit 1091 shaping vbr sustained 4m
set interfaces at-0/0/0 unit 1091 shaping vbr burst 1
set interfaces at-0/0/0 unit 1091 atm-scheduler-map MPIPN8256047-atmaccess
set interfaces at-0/0/0 unit 1091 family inet mtu 1500
set interfaces at-0/0/0 unit 1091 family inet address 10.225.7.101/30
m10-01-re0> show interfaces at-0/0/0.1091 detail
  Logical interface at-0/0/0.1091 (Index 100) (SNMP ifIndex 809) (Generation 6749)
    Flags: Point-To-Multipoint SNMP-Traps 0x4000 Encapsulation: Ether-over-ATM-LLC
    Traffic statistics:
     Input  bytes  :           2886766117
     Output bytes  :           9838109560
     Input  packets:             19553363
     Output packets:             20631712
    Local statistics:
     Input  bytes  :              3209219
     Output bytes  :              3297334
     Input  packets:                46680
     Output packets:                47173
    Transit statistics:
     Input  bytes  :           2883556898               320048 bps
     Output bytes  :           9834812226              1114680 bps
     Input  packets:             19506683                  307 pps
     Output packets:             20584539                  296 pps
    Protocol inet, MTU: 1500, Generation: 2508, Route table: 25
      Flags: Sendbcast-pkt-to-re, Is-Primary, User-MTU
      Addresses, Flags: Is-Preferred Is-Primary
        Destination: 10.225.7.100/30, Local: 10.225.7.101, Broadcast: 10.225.7.103, Generation: 1899
    VCI 1.91
      Flags: Active, Shaping, Multicast
      VBR, Peak: 4mbps, Sustained: 4mbps, Burst size: 1
      Total down time: 00:31:45 sec, Last down: 66:51:41 ago
      EPD threshold: 0, Transmit weight cells: 0
      ATM per-VC transmit statistics:
       Tail queue packet drops: 29441
      Traffic statistics:
       Input  bytes  :           3443743742
       Output bytes  :          10291252760
       Input  packets:             19553318
       Output packets:             20602220
      ATM CoS statistics:
       VC CoS mode: strict
       fc-be 0:
        Priority: low, Transmit weight percent: 11
        RED queue depth: 50000, Low PLP threshold: 50, High PLP threshold: 10, Low PLP max threshold: 50,
        High PLP max threshold: 10
        Output bytes  :           9764680283
        Output packets:             18046475
        Packet Drops  :                29441
       fc-af1 1:
        Priority: low, Transmit weight percent: 18
        RED queue depth: 20000, Low PLP threshold: 80, High PLP threshold: 60, Low PLP max threshold: 80,
        High PLP max threshold: 60
        Output bytes  :                 1379
        Output packets:                   15
        Packet Drops  :                    0
       fc-af2 2:
        Priority: low, Transmit weight percent: 30
        RED queue depth: 20000, Low PLP threshold: 100, High PLP threshold: 100, Low PLP max threshold: 100,
        High PLP max threshold: 100
        Output bytes  :             11656530
        Output packets:                18681
        Packet Drops  :                    0
       fc-ef 3:
        Priority: high, Transmit weight percent: 41
        RED queue depth: 10000, Low PLP threshold: 100, High PLP threshold: 100, Low PLP max threshold: 100,
        Output bytes  :            514914568
        Output packets:              2537049
        Packet Drops  :                    0
     OAM F5 cell statistics:
      Total received: 1874, Total sent: 1874
      Loopback received: 0, Loopback sent: 0
      RDI received: 0, RDI sent: 1874
      Last received: Never, Last sent: 66:19:59
      AIS received: 1874, AIS sent: 0
      Last received: 66:19:59, , Last sent: Never
m10-01-re0>
    Input packets : 19561774
    Output packets: 20639042
    VCI 1.91
      Total down time: 00:31:45 sec, Last down: 66:52:14 ago
        Input packets : 19561662
        Output packets: 20610105
m10-01-re0>
Joseph W. Doherty
Could you also clarify your traffic flows.  I.e. how you apply QoS to a mixture of internal (?) business class traffic and Internet traffic?
Also could you clarify where all QoS is deployed.  I.e. you mention PE to CE, but you say your (?) only allowing 10% for default class, on PE?
Hi Joseph,
Please check config I have uploaded CE config which should give idea of QoS applied to Business and Internet traffic.
Core is Juniper and the PE(at branch site) has four queues for different traffic flows from PE to CE.
EF queue has given 41% of 4M bandwidth and rate-limited.
Two data queues have been given 48% of remaining bandwidth and allowed to burst upto port speed.
Default queue has been given 11% of remaining bandwidth and allowed to burst upto port speed.
Inderjeet Singh
Sorry.. I forgot to upload the documents.. please find it here. Text file has configuration and other stats. Two .png files shows the latency for BA and RT data queues.. We are monitoring each class traffic from a central monitoring station and these pictures were taken from that server.
