High txload and rxload values for VLAN interface
luis Ibarra
Hi everyone
I am trying to figure out if some of my VLAN interfaces are having issues.  I was looking for packet loss and saw the following on some of my VLANs, see orange highlights below.  I am get very high numbers for my tx and rx loads, but my reliability is still 255/255.  Is this an issue?  I can't find anything online about VLAN interfaces having high tx or rx loads.
Thank you
Luis
Vlan12 is up, line protocol is up
  Hardware is Ethernet SVI, address is b07d.4700.1567 (bia b07d.4700.1567)
  Internet address is X.X.12.1/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 255/255
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 9w1d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1399548000 bits/sec, 131394 packets/sec
  5 minute output rate 205000 bits/sec, 122 packets/sec
     731866565450 packets input, 976358742737824 bytes, 0 no buffer
     Received 0 broadcasts (30873 IP multicasts)
     904589193 packets output, 458849071216 bytes, 0 underruns
     0 output errors, 0 interface resets
     0 unknown protocol drops
and
Vlan15 is up, line protocol is up
  Hardware is Ethernet SVI, address is b07d.4700.1554 (bia b07d.4700.1554)
  Internet address is X.X.15.1/24
     reliability 255/255, txload 1/255, rxload 249/255
  5 minute input rate 979204000 bits/sec, 91685 packets/sec
  5 minute output rate 147000 bits/sec, 90 packets/sec
     494602899301 packets input, 661946671057181 bytes, 0 no buffer
     Received 0 broadcasts (19808 IP multicasts)
     440301572 packets output, 103441792223 bytes, 0 underruns
15 Replies 15
Luis,
Thanks for your information. But any method for solving this problem?
Richard,
In my environment, it is also related to video editing. So any recommended model of access swtich from you? Thanks a lots
