Home lab assistance
sgrg07
Hi all,
I am working on setting up a home lab. I have an ISP wireless modem connected to a cisco 2811router.
I've done a static route from the cisco router to the internet via the modem. I can ping 8.8.8.8 but cant ping anything else. Does this mean that the cisco router is not connected to the internet?
Also is there a need for a route back from the internet/modem to the router?
Any feedback would be appreciated.
Many thanks
29 Replies 29
Hi @sgrg07
You need to configure NAT on you router.
Take a look on how to setup NAT on your router and you will be able to access the internet.
-If I helped you somehow, please, rate it as useful.-
Julio E. Moisa
You need a NAT to translate the private networks to the Public IP or to IP provided by the Wireless modem. Imagine your wireless modem provide IP address from the subnet 192.168.1.0/24 and the gateway is 192.168.1.1, you can set up your router like:
PC ----- g0/1 Router g0/0 ----- WIFI Modem.
interface g0/0
description TO-WIFI-MODEM
ip address 192.168.1.2 255.255.255.0
ip nat outside
no shutdown
interface g0/1
description MY-LOCAL-NETWORK
ip add 10.0.0.1 255.255.255.0
ip nat inside
no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.1.1 name TO-INTERNET
192.168.1.1 represents the gateway of the network provided by the WIFI Modem but also you can set up the next hop address (i think you already know what IP is because you can ping the public IP 8.8.8.8)
ip access-list standard MY-NETWORKS
permit 10.0.0.0 0.0.0.255
ip nat inside source list MY-NETWORKS interface g0/0 overload
I have configured a PAT (A type of NAT) to provide translate may private networks to other network who already have Internet access, so my private networks will have access to Internet through that procedure.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
I have an #ip nat in in my LAN interface and #ip nat outside on my WAN interface. I have done a NAT overload (PAT)  on the interface facing the wifi modem permiting the LAN network.
What my problem is that I can only ping the google dns servers and nothing else.
I also have a switch connected to my LAN interface from where I cant even ping the Modem's ip (192.168.1.1). the default gateway for the switch is the ip of the the router's LAN interface.
Put your config here mate and let us help you.
 Better attach in txt file.
You don't have 'ip nat inside' on your LAN.
And you should use "ip nat outside source list ..."
Correct that and try again.
Hi ,
thanks for point that out. I have added that
and also shouldn't it not be ip nat source inside .. since we're tranlating LAN addresses in to public ?
Put outside and test.
Hello
@sgrg07 wrote:
Hi all,
The router you say can ping google dns, but nothing else, so i am curious to what static route you have applied, as usually the wan facing interface on your rtr that is attaching to the isp modem is dhcp so theory the rtr should obtain a ip address/subnet mask/default gateway via the ISP
Now the usual default static route would be something similar to this ( providing your receiving a dhcp wan address <---- ip route 0.0.0.0 0.0.0.0 <waninterface> dhcp
Now although it is necessary to NAT, In this case it may not be applicable as you DONT state what the modem is doing, it maybe the modem is already performing NAT on your behalf and as you don't mention any non routable subnets for the local area network being configured i would say at this time you dont require any static routes defined on the isp modem pointing back to your router as the connected interface between the rtr and the isp modem would do the trick anyway.
Can you provide the running configuration of the rtr so we can review it and if applicable provide you with suggestions to get you up and running.
res
Paul
Kind Regards
Paul
Hi Paul,
Thanks for you assistance.
The interface connected to modem obtained ip from the dhcp in modem.
I have a static route 0.0.0.0 0.0.0.0 192.168.1.1 from the router to the internet.
I have got PAT on the router for my LAN network.
My switch on my LAN network cannot ping anything
I will post the config in txt version so you guys can figure out what needs to be done.
Hello
Regards just you router config you posted can you try this:
no ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
int FastEthernet0/1
ip nat inside
res
Paul
Kind Regards
Paul
Just done that.
Still can only ping google DNS
Alright.
From your PC or laptop, if you run the command:
nslookup www.google.com
What answer does it brings?
What I mean is, you need NAT but you also need DNS server.
 On you DHCP scope you can pass the DNS server 8.8.8.8 to your machine or you can config it statically.
 Check that and let me know.
Hello
From your rtr only can you :
ping 73.163.4.161 source fa0/1
This will tell you two things that wan/NAT connectivity is working from your Lan subnet
Then on a client pc statically assign ( as no dhcp server is active for your lan subnet from what you have posted)
Ip address 10.0.0.x
Subnet =255.255.255.0
D/G 10.0.0.1
DNS= 8.8.8.8
Also
no ip nat pool HOME 192.168.1.1 192.168.1.3 netmask 255.255.255.248
no ip nat inside source list HOME_LAN pool HOME overload
ip nat inside source list HOME_LAN interface fa0/0 overload
test again from cleint
ping 73.163.4.161
ping cisco.com
res
Paul
Kind Regards
Paul
