How can i share a single 3560 poe, between 4 routers.
Duwaine Winder
I am building out a voice lab, and looking to maximize the excess ports on a 3560 poe to all sites (HQ, BR1, BR2 and PSTN). I have tried a pvlan configuration but it doesn't work as expected (or maybe i'm doing something wrong).  Additionally I need to source dhcp from multiple places to each pvlan.
Any suggestions or shared configurations would be appreciated.
Reza Sharifi
Are you trying to put all 4 routers in the same vlan or 4 different vlans.
If it is the same vlan just connect each router to a port on the 3560 and put all the ports in the same vlan/subnet and give each router an IP address:
on the 3560
config t
vlan 100
name mgmt-vlan
exit
interface vlan 100
ip address 10.10.10.1 255.255.255.0
no sh
interface gi0/1
description port-to-HQ-router
switchport
switchport mode access
switchport access vlan 100
do the same for other 3 ports
assign an IP address to HQ router port that connects to port gi0/1 on the switch
config t
interface x/x
ip address 10.10.10.2 255.255.255.0
4 different vlans, each serving dhcp to clients assigned to vlan
if 4 different vlans than you need 4 ip segments with 4 vlans
example:
QH router 10.10.10.0/24 vlan 100
BR1 router 10.10.11.0/24 vlan 101
BR1 router 10.10.12.0/24 vlan 102
PSTN router 10.10.13.0/24 vlan 103
You also need to create layer-2 and layer-3 for all the vlans on the 3560 and put the each port in a different vlan and create 4 SVIs (one per vlan)
example
vlan 100
name HQ-vlan
exit
interface vlan 100
no sh
vlan 101
name BR1-vlan
exit
interface vlan 101
ip address 10.10.11.1 255.255.255.0
no sh
and so on
also turn on "ip routing" on the 3560.
