How do I configure three separate internal network (private) to access the internet using a single ISP nat outside access
Wendell Taroa
Hello, hope there'd be someone to share some "CISCO luminous sparks" in my network issue.
I have a network where we plan to configure three VLANs for our internal network using private ip address space.
We are using an ISR Cisco 892 FSP router which has switch port which the ISP took advantage of to configure one VLAN which
they name Data. After which one of the switch port was configured with switch port access VLAN 200 which is then connected to a
our unconfigured Cisco 2960 X series switch connecting our internal network. We do not have a server and are using our router to
provide dhcp deployment and with such a network with greedy users and applications, congestion became and issue cos its a to big broadcast
as per my ip dhcp binding results. I must find a way to rectify this and its going to be through VLANs.
Extracts of the necessary configurations I wish to share are here to give you
an idea of our network logical configuration:
interface Vlan200
description DATA
ip address 10.188.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT-LIST interface Virtual-PPP10 overload
ip route 0.0.0.0 0.0.0.0 Virtual-PPP10
ip route 172.18.0.0 255.255.0.0 172.18.0.5
ip access-list standard NAT-LIST
permit 10.188.1.0 0.0.0.255
Following this configurations, I would like to configure other two networks, network 10.188.2.0 and Network 10.188.3.0
to also have a similar access as above, utilizing the same NAT point (Virtual-PP10 overload).
Please share some CISCO "luminous sparks" project.
2 Accepted Solutions
your best option would be to use subinterfaces on the 892, and connect one of the routed ports to the 2960X (make sure the port connected on the 2960X is a trunk port). Below is a sample config. Make sure you create the Vlans (which are arbitrary, you might use other Vlan numbers) on the router as well:
ip dhcp excluded-address 10.188.1.1
ip dhcp excluded-address 10.188.2.1
ip dhcp excluded-address 10.188.3.1
ip dhcp pool VLAN200
network 10.188.1.0 255.255.255
default-router 10.188.1.1
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool VLAN201
network 10.188.2.0 255.255.255
default-router 10.188.2.1
ip dhcp pool VLAN202
network 10.188.3.0 255.255.255
default-router 10.188.3.1
interface FastEthernet8
description Trunk to 2960X
interface FastEthernet8.200
encapsulation dot1q 200
ip nat inside
interface FastEthernet8.201
encapsulation dot1q 201
ip address 10.188.2.1 255.255.255.0
ip nat inside
interface FastEthernet8.202
encapsulation dot1q 202
ip address 10.188.3.1 255.255.255.0
ip nat inside
permit 10.188.2.0 0.0.0.255
permit 10.188.3.0 0.0.0.255
Wendell Taroa
It was really awesome to look back in the lane where intellectual freedom is really expressed in technology, this piece of question and the remarkable response has been a great and spontaneous benchmark where we actually kicked off from in our server room some years back, it would not have been so without the help from cisco community. I just love it.
Sergey Lisitsin
Wendell Taroa,
All you need to do for it to happen is add your new LAN interfaces, for example, copy the configuration of VLAN 200, giving it a new VLAN number and new IP address. Also, add the new network into your NAT access list. That's all.
For example:
interface Vlan201
description DATA1
ip nat inside
That's it
Giuseppe Larosa
Hello Wendell,
you can create additional Vlans 201, 202 on both the router C892 and Catalyst 2960 (on Cat2960 you probably need to create Vlan 200 too if it is used with default configuration ).
Router
config t
vlan 201
name DATA2
vlan 202
name DATA3
exit
int vlan 201
desc DATA2
ip nat inside
no shut
exit
int vlan 202
desc DATA3
ip nat inside
no shut
exit
Now the router physical port to the switch has to be configured in the following manner
interface gi2
description to the C2960 giX
switchport
switchport mode trunk
switchport trunk allowed vlan 200,201,202
The NAT ACL has to be updated as follows
You need to gain access to the switch via a console cable and to configure it for the three Vlans and to be managed remotely
Let us suppose the default username cisco cisco is still there you access on the console with it
if you get enabled prompt #
You can do the following
config t
vlan 200
name DATA
vlan 201
name DATA1
vlan 202
name DATA2
exit
int vlan 200
ip address 10.188.1.2 255.255.255.0
description management
no shut
exit
ip default-gateway 10.188.1.1
The switch port connected to the router can be found using
show cdp neighbors
Let us suppose it is gi0/0 you need to configure it as a trunk carrying Vlans 200,201,202
interface gi0/0
description to router:gi2
switchport
WARNING NOTE:
There is an important impact in this change:
up to now you have used default configuration on the switch that means all ports are access ports in Vlan 1.
With the proposed change you need to move all access ports to vlan 200, then selected ports will be in vlan 201 and other selected ports in vlan 202.
config t
interface range gi0/1 - 24
switchport
switchport access vlan 200
to be able to telnet to the switch you need the following config
config t
line vty 0 4
login local
login privilege 15
exit
You are recommended to configure a username and password pair of your choice and to remove the default cisco/cisco
username  myadmin privilege 15 password <your-password>
It is wise also to set an enable passord on the switch if you are not able to reach level 15 by telnet
enable secret <your-secret-password>
note: the enable secret will be encrypted you must remember the password you have entered to be able to use it later
Hope to help
Giuseppe
ip nat inside
ip nat inside
ip nat inside
Wendell Taroa
