How do I find whether its desirable or auto in trunk
saishreevj
configured trunk as desirable and  auto to form trunk. How do I find whether its desirable or auto on interface via cli. Port config is not showing that information as well.
pman
Hope this helps you understand,
try this command:
show interface ethernet x/x switchport
Switch#show interfaces fastEthernet 0/1 switchport
for example:
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: All
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast block
with DTP:
SW1#show interfaces 1/0/32 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
pman
try this command:
for example:
Switchport: Enabled
Voice VLAN: none
Protected: false
with DTP:
Switchport: Enabled
