How do I set inferior EIGRP metrics during redistribution?
davinci
I want a select group of BGP routes to have inferior EIGRP metrics upon redistribution.  Will this route map and set metric command work?  Or will the metric from redistribute command override the settings?
router eigrp 1
redistribute bgp 65012 metric 10000 100 255 1 1500 route-map BGP-REDIST
route-map BGP-REDIST permit 20
match ip address prefix-list BACKUP-CLOUD-ROUTES
set metric 1 16777215 1 1 1500
ip prefix-list BACKUP-CLOUD-ROUTES seq 10 permit 192.168.1.0/24
ip prefix-list BACKUP-CLOUD-ROUTES seq 20 permit 172.16.0.0/16
Giuseppe Larosa
Hello @davinci ,
the best way to implement this should be to avoid the use of the metric on the redistribute command by adding a final route-map clause like
route-map BGP-REDIST permit 30
set metric 10000 100 255 1 1500
then in router eigrp 1
no redistribute bgp 65012 metric 10000 100 255 1 1500 route-map BGP-REDIST
redistribute bgp 65012 route-map BGP-REDIST
In theory the most specific metric should apply so your setup should work, the solution proposed above should work for sure as you configure the set metric at route-map level for all routes.
Hope to help
Giuseppe
Martin L
that is interesting situation; never had it; since you do have set it up; what the end result ?
Giuseppe Larosa
Hello @davinci ,
Hope to help
Giuseppe
Excellent advice, Giuseppe.  Thank you.  This solution worked in GNS3 lab and will now go into production.  EIGRP composite metric was manipulated as expected.
