How do I set ip audit notify log?
paul.vickers
Trying to emulate an existing working config.
But don't seem to be able to recreate the following config items...
ip audit notify log
ip audit po max-events 100
ip audit signature 1107 disable
ip audit signature 2000 disable
ip audit signature 2004 disable
ip audit signature 4050 disable
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
If I type ip audit notify log at the privileged or config prompt, I get an invalid input error
Jon Marshall
Hi Paul
It's probably because you don't have the right version of IOS on your router. Could you let us know what version of IOS you are currently running and on what hardware.
Jon
yep, you are right.
Have the extended security feature set. need the extended IP feature set to do IP auditing.
